Wastegate dilema....
Right, i'm having a bit of a think about my set-up.
I went to emerald to get my car tuned, and because my boost controller (n75 valve) wasn't working they could only tune it to 0.5 bar of boost. They also said i'd need a bigger wastegate (mine is 38mm turbosmart) as i was getting boost creep when on boost.
I've heard a few rumours about smaller wastegates being better for higher boost, and larger wastegates being better for lower boost, is this true??
My question is;
Do i keep the wastegate i've got, buy a new n75 valve and hope when i wind the boost up it works...
Or buy a new bigger wastegate, n75 and then hope it works?
i have 38mm waste gate .5 bar fine 1 bar fine 1.5 bar fine 1.7 bar fine oops there goes my drive shaft. Try using a 1 bar wastgate spring instead of using the emerald to control the boost.
Yeah that was the other thing, whether to junk the n75, and just run off of the spring.
I've heard a few rumours about smaller wastegates being better for higher boost' date=' and larger wastegates being better for lower boost, is this true??
Yeah that's true. High boost on most turbos bypasses very little exhaust gas, so WG sizes can be smaller. Some race engines use the turbo's maximum boost pressure all the time, so they don't have wastegates at all.
Low boost bypasses a lot more exhaust through the WG and big gates therefore cause less of a restriction (compared to small ones) when dumping it all back into the exhaust system, so you get less back pressure in the manifold. And less back pressure in the manifold means less of the intake fuel/air is contaminated with exhaust and you can run more advance, which = more power :-)
I'm with Matty actually. I just run a 13psi spring with no boost control and it works for me :-) I use a Tial 44mm though, which is quite a large fella. But it gets to and holds 13psi perfectly with no spikes or creeping etc.
If you are running into creep issues, that means your WG or associated pipe work can't shift the bypassed gases quickly enough, so perhaps upgrading to the 44mm might help that. What turbo are you running?
Electronic boost control is OK for controlling boost in the lower gears and holding the spring shut for as long as possible, but I prefer the simple approach. It's a lot more reliable and predictable!
