kie_dub 0 Posted March 28, 2010 Report Share Posted March 28, 2010 I went to start my car ( 1996 obd2 mk3 vr6 turbo ) yesterday morning but it didnt want to play ball. Turned on the ignition, all clocks lit up as normal, fuel pump sounds like it normally does (uprated and noisey) injectors are squirting as they should, went to turn it over, the starter motor turns over but the engine just isnt firing up! left it 10 minutes and tried again but nothing. Had to abandon it as i had plans and got picked up. im not with the car now so i will try what is suggested when i get home.So yesterday when it wouldnt start i made sure that all the ignition leads where pushed onto the plugs properly and onto the coilpack but it didnt do anything. Im no mechanic so i need as much info as i can please p.s i havnt had any issues like this before with it not starting from cold, not used the car for a week it was fine when i switched it off the weekend before and dont know if this helps but when im turning it over the oil light starts to flash. Ive got an oil leak but i know where its coming from (an oil sensor) and i have got the part ready to go onAny help appreciated!!!Kieron Link to post Share on other sites
thegoth 5 Posted March 28, 2010 Report Share Posted March 28, 2010 Have you checked for a spark? Link to post Share on other sites
kie_dub 0 Posted March 28, 2010 Author Report Share Posted March 28, 2010 a spark from where, each lead? if so then no, only checked the above so far Link to post Share on other sites
matty.vrt 120 Posted March 28, 2010 Report Share Posted March 28, 2010 had this problem, it was the crank position censor. Link to post Share on other sites
vr6_super 0 Posted March 28, 2010 Report Share Posted March 28, 2010 i echo what matty came up with, sounds like same prob i had with a previous car.basically the sensor sends a signal to the ignition module to start the firing order. if theres no signal then theres no sequence to start, thus you will just keep turning over. my prob was oil had somehow got into sensor and heated up and fekd it. check to see if theres oil on yours.easier thing to do first is check to see if theres a spark to begin withpeace out Link to post Share on other sites
UnitedMotorsport 55 Posted March 28, 2010 Report Share Posted March 28, 2010 Its not the crank sensor if the injectors are firing and the fuel pump is running! Link to post Share on other sites
kie_dub 0 Posted March 28, 2010 Author Report Share Posted March 28, 2010 so if its not the crank sensor what could be next? btw im running c2 management, Ive had problems in the past with the car not starting whilst very hot (just under 100 degrees (oil) ) but never when cold Link to post Share on other sites
matty.vrt 120 Posted March 28, 2010 Report Share Posted March 28, 2010 how do you know the injectors are firing have you had a plug out. Link to post Share on other sites
vr6_super 0 Posted March 28, 2010 Report Share Posted March 28, 2010 first and foremost he needs to check to see if theres a spark, having an oil leak doesnt help even if it is a sensor probquick question tho, is it a sensor prob or an actual leak? Link to post Share on other sites
kie_dub 0 Posted March 28, 2010 Author Report Share Posted March 28, 2010 my oil leak.. the oil is leaking from an oil sensor, ive got the part just need to fit it. Im not someone that leaves a problem to get worse i like to get it sorted asap. I can hear the injectors, they sound the same as they always have done. Like ive said i aint with the car at the minute so i just need a list of things if you get me so i know where to start and what to look for. Where should i check for a spark? sorry im a dunce when it comes to mechanics Link to post Share on other sites
kie_dub 0 Posted March 28, 2010 Author Report Share Posted March 28, 2010 would it be a good idea to vagcom the car? If so ill need to buy a lead and software off ebay, ive been looking but there are too many i dont know which one to choose! :s if it needs vagcom could someone who knows give me a link to the right one on ebay please, ta ;D (1996 obd2) Link to post Share on other sites
kie_dub 0 Posted March 28, 2010 Author Report Share Posted March 28, 2010 bump Link to post Share on other sites
J5KE F 0 Posted March 28, 2010 Report Share Posted March 28, 2010 I just had a similar prob with mine.. Turns out engine was flooding with fuel but from the nitrous fuel solenoid.. Changed plugs (which where black and wet through with fuel, leads and coil pack..)i'd suggest checkin plug condition and spark on each one by turning over engine a few times and holding the plug (with an insulated pair of pliers) against a decent earth (but away from the fuel lines!) Link to post Share on other sites
kie_dub 0 Posted March 28, 2010 Author Report Share Posted March 28, 2010 My mate got shocked the last time we did this it was actually hilarious lol, from my point of view anyway! Right so im going to check the spark (by doing the above) check and clean up my plugs, and possibly plug into diagnostics ( can anyone recommend which vagcom to get pleassee, link if poss)Then go from there. btw where can the crank shaft censor be found? might aswel check it just incase Link to post Share on other sites
RAPgolfvr6182 2 Posted March 28, 2010 Report Share Posted March 28, 2010 its found on the crank shaft at the crank pully Link to post Share on other sites
J5KE F 0 Posted March 28, 2010 Report Share Posted March 28, 2010 Any vag com really. U can do enough from the shareware available and get the lead from fleabay for about 15-20 squids! Link to post Share on other sites
kie_dub 0 Posted March 29, 2010 Author Report Share Posted March 29, 2010 I've just got myself a vagcom off of ebay, cost me under a 10er with free 1st class postage for the lead, driver and shareware download. Can't moan about that! Should be getting down to fixing the car tonight hopefully, hope its nothing serious Link to post Share on other sites
kie_dub 0 Posted March 31, 2010 Author Report Share Posted March 31, 2010 Right ive just been having a fiddle with the car trying to get it started. Found that when i was turning the ignition from on position to start the fuel pump was cutting off. When the ignition is turned to on there is a strange clicking sound coming from the fuse box area. Found that the noise was coming from a relay in the fuse box.something to do with the fuel. So removed this and tryed my mates relay in my car, but his does the clicking sound in my car aswel! :s Put my relay into his car and his works with mine in... very strangeso anyone got a clue pleasssee? Link to post Share on other sites
kie_dub 0 Posted April 1, 2010 Author Report Share Posted April 1, 2010 bump Link to post Share on other sites
stewvr6 0 Posted April 1, 2010 Report Share Posted April 1, 2010 to check for a spark get another spark plug and attach it to each individual ht lead and turn the engine over, place the spark plug against theslam panel to earth the plug. if it is working fine you will see the spark. if you were to remove a plug and do it you would spray fuel every where, so this is the easy answer. if the immobiliser is wired in to the starting circuit then either the starter motor wouldn't turn over or the solenoid wouldn't cick across. Link to post Share on other sites
legvw 0 Posted April 1, 2010 Report Share Posted April 1, 2010 Could it be your ignition switch? Mine cuts power between start and ingition on, jsut worn out through age.If that relay is clicking on and off frequently then it means something is only just switching the relay on, but not enough to keep it on, which makes it click like mad.If you can, try a new, or known working switch. Link to post Share on other sites
stewvr6 0 Posted April 1, 2010 Report Share Posted April 1, 2010 if your relay works on your mates car then it will work on yours. have you got a spark first! if there is no spark then it would point more towards the ignition module between the coil pack and ecu if i am right in my thinking. try asking xyber on swdubs forum hei s pretty clued up on this kind of thing Link to post Share on other sites
J5KE F 0 Posted April 1, 2010 Report Share Posted April 1, 2010 Try another key as the prognosis could sound like immobiliser issue.. The key has a chip and the ign barrel has a transponder ring to pick up the signal. I have had faults with both over the years.I'm sure there is information in prem members section on alarm and immob faults..? Link to post Share on other sites
kie_dub 0 Posted April 3, 2010 Author Report Share Posted April 3, 2010 Itd got a clifford alarm fitted was thinking it may be down to the immobilizer but its going off. Right just tested the spark and....... There is no spark! So what could It be, coilpack? Link to post Share on other sites
kie_dub 0 Posted April 5, 2010 Author Report Share Posted April 5, 2010 Bump Link to post Share on other sites
