GVK's mk2 VR6 track car
I lurk around here and post now and again, live in the Worcester area.
Been around Dubs since about '95 on and off and had my current mk2 since 2002. It was bought as a stock 16v and has evolved over the years into a track day car but still road-useable...ish :lol:
Gary
If you're looking for 'stance' 'air' or a leather clad engine bay..... you've clicked the wrong thread!
Engine spec
OBD2 2.8 VR6
Dougherty racing 268° camshafts
Carbonio cold air intake
De-catted
Unorthodox racing alloy flywheel
02J shifter mech and shift tower.
Raceland stainless tubular manifold 'header'
02A cable change box DPA gearset
3.68FD
Peloquin ATB diff.
mk IV R32 shift lever and cable mech.
235mm 11row oil cooler.
C2 UK NA 268 chip,de-speed limited and 7200rpm limiter.
Chassis/brakes
H&R VR6 coil overs
H&R 25/28mm anti roll bars (rear 3 way adjustable)
Wide track conversion (using Passat bits) + 32mm front... + 20mm rear (10mm spacers behind stub axles)
Poly bushes throughout.
Eibach front strut brace
Seat Ibiza Cupra 280mm brakes
DS2500pads
Braided lines
Motul RBF600 fluid
Toyo R888 195/50x15
Team Dynamics 'dtm' 7x15
Inside
Stripped
Safety Devices 6 point roll cage
OMP RS seat (drivers)
OMP eco seat (pax)
LUKE harnesses
MOMO steering wheel
OMP steering wheel spacer
Sparco black pedals
Quaife nylon gearknob
MkIV R32 shifter mounted on tunnel
OBD-II-shop ECU data interface. [thanks to CrazyDave for the build of that!]
Donor Passat VR6 StationWagen 0BDII £500 ukp
Some progress pics.
Thanks to Jochen at http://www.frozenspeed.com
Splashing around Castle Combe
Full beam ! [0 o o 0]
GTI International 2008.
GTI Inters 02
..... it was a tidy car before I started ****ing about with it!
Mallory park 2004 running Michelin clio cup full slicks.
Castle Combe action day report in Golf+ 2004
By chance bumping into Bill Brockbank (Badger5) this morning...
Had the car on a Dyno Dynamics rolling road (Recognised as the most accurate dynos in the industry) today at http://www.ajecracing.co.uk near Cheltenham.
Figures were 205.2hp which I'm pleased with
Everyone agreed it sounded nice too!
Videos @ http://www.youtube.com/user/GVKmotorsport and on Vimeo http://www.vimeo.com/user645578
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
Went to GTI fest yesterday - previous best was 14.3@96 on R888s
Turned up on Kumho road tyres and was very Suprised to run a 14.2@100 on first run - all down to mapping from Matt @ C2 motorsports UK
Ran a 14.1 @ 99 later in the day, it'll do until the GT3582R goes on there....
Letstorquebhp said
Power at Flywheel (BHP) : 205
Weight without Driver (KG) : 1100
Power to Weight Ratio (BHP Per Ton) : 189.36
0 - 60 (Secs) : 5.93
0 - 100 (Secs) : 14.82
60 - 100 (Secs) : 8.89
Quarter Mile (Secs) : 14.32
Terminal Speed (MPH) : 98.32
Drag Strip Quarter Mile (Secs) : 14.12
Drag Strip Terminal Speed (MPH) : 100.07
Santpod said
60ft 2.2409 (road tyres... R888 can give me 2.1 60ft previously)
330ft 6.1148
1/8 ET 9.2760
1000' ET 11.9578
1/4 ET 14.2147
1/4 MPH 100.08
Should help with Kesselchen, and those c**ts that don't pull over on trackdays in their Evo/Scooby/why...
