DreadedDev 0 Posted April 30, 2010 Author Report Share Posted April 30, 2010 Can anyone tell me the internal diameter of the main pipe and the spur, planning on getting a joint and cutting the pipe, but don't want to have to take the pipes off to measure them as it looks like the hose clips are not designed to come off and on again... Link to post Share on other sites
VR6Nat 9 Posted April 30, 2010 Report Share Posted April 30, 2010 Just incase you cant do it this way and you need to order the hose from VW... here is the part numbers.... you will need number 21 (hose)then clips 30, 33 and spring 22 Link to post Share on other sites
VR6Nat 9 Posted April 30, 2010 Report Share Posted April 30, 2010 sorry that came out pants... Link to post Share on other sites
VR6Pete 1,455 Posted April 30, 2010 Report Share Posted April 30, 2010 another option is to check classifieds section to see if anyone is breaking a VR6... plenty of them going about at the moment! Link to post Share on other sites
DreadedDev 0 Posted April 30, 2010 Author Report Share Posted April 30, 2010 sorry that came out pants... Thanks for that, I can't see anything like that spring clip 22 on there now, so I'm guessing that's if you have the electronically adjusted air conditioning.....Interestingly the guy at VW quoted me ~£40 first off, then asked if i had air-con and quoted me ~£80.... I'm going to go for repairing it with the pipe repair tape you get and then look at replacing it properly..... so that's for the parts list as I probably would have forgotten to get the clips as well!!! Link to post Share on other sites
