Jordz 0 Posted April 27, 2010 Report Share Posted April 27, 2010 Hi guys, im in the middle of doing a VR conversion. Being quite tight with money, I desided id buy a doner car (Mk3 R reg with eibach coillies for £500!) and have only now came across this problem. Me and my mate started taking apart the Mk3 and discovered that the rad fan assembly is built in to the slam pannel setup. I presumed that, like my Mk2, the fans would just separate from the rad but obviously not. Now i know that you can get a fan setup that is not attached, but i cant seem to find them anywhere (ebay haha). To be honest im quite p*ssed off as the rad is perfect. Any advise would be much appreciated... Link to post Share on other sites
aaronmk2 3 Posted April 28, 2010 Report Share Posted April 28, 2010 You can use the mk3 rad and fans but u have to do some trimming to the plastic to get it to fit.either that or use corrado vr6 set up its a direct fit for the mk2 and is alot neater and oe lo oking in my opion check the mk2 vr6 forum fella they will help u out as they have a conversion guide Link to post Share on other sites
Jordz 0 Posted April 28, 2010 Author Report Share Posted April 28, 2010 Ok Doke, i will need to look out for a 'rado radiator then. Im kinda gutted because the rad is near perfect due to the fact the aircon element took most of the abuse but awell, needsmust. Thanks for the advice Link to post Share on other sites
VR6Pete 1,455 Posted April 28, 2010 Report Share Posted April 28, 2010 dont forget, with a corrado radiator, you will also need corrado top and bottom radiator hoses !! Pete Link to post Share on other sites
jonesy187 0 Posted June 4, 2010 Report Share Posted June 4, 2010 are you using clutch cable if not, you can use the corrado peddle box Link to post Share on other sites
euanm1979 0 Posted June 6, 2010 Report Share Posted June 6, 2010 i might take the rad and fans off your hands if you decide to go with the rado set up mate, let me know if you do and what sort of money you'd be looking for. Cheers Link to post Share on other sites
Jordz 0 Posted June 6, 2010 Author Report Share Posted June 6, 2010 Sorry mate, just cut back everything from the fans to fit the mk2 as i cant afford/find corrado setup Link to post Share on other sites
euanm1979 0 Posted June 12, 2010 Report Share Posted June 12, 2010 nae worries, cheers anyway Link to post Share on other sites
bentheboffin 1 Posted July 6, 2010 Report Share Posted July 6, 2010 u can use a seat cordoba sx 1.6 fan assembly with the mk3 rad, looks a loads better than a cut down mk3 item Link to post Share on other sites
