void_main 0 Posted April 30, 2010 Report Share Posted April 30, 2010 Hi guys,My first time here, so hi!Just bought myself a 2000 mk4 4motion (74k, reccaro seats, satnav, etc) and very happy.My rear brake pads were a little low so I've had them replaced and its stopped most of that unbearable sqeeking noise when braking. Whilst I was looking at the brakes I noticed that theres quite a bit of corrosion on the inner part of my vented disks - the standard 4mo disks as far as I know.Question is, should I be thinking of replacing them? I'd like everything to be in good working order.Also, I've seen lots of upgraded brakes for sale, cross drilled and the likes and quite fancy some, does anyone know if fitting them means informing ones insurance company? If so do they look favorably upon brake upgrades? If my brake performance is increased, surely this means I'm less likely to have an accident hehe?!! Link to post Share on other sites
cabrioman 6 Posted April 30, 2010 Report Share Posted April 30, 2010 a brake up grade is always good never a bad choice mate .... dont really need to tell insurance company ... if they are heavily croded on the inner edge id look at replacing them mate ... Link to post Share on other sites
void_main 0 Posted April 30, 2010 Author Report Share Posted April 30, 2010 cheers dude, might post a picture tomorow if I get time! Link to post Share on other sites
RAPgolfvr6182 2 Posted May 1, 2010 Report Share Posted May 1, 2010 if there liped id replace them ie where the pads worn the middle of the disc away leaves a lipped edge on the side and can cause brake squealing Link to post Share on other sites
bungy 2 Posted May 1, 2010 Report Share Posted May 1, 2010 Depends really on how much corrosion is inside the vented area and any scoring / wear on the disc face. They are not too expensive to replace and a higher sinter rating pad will increase your braking performance aswell. Russ ( b road blaster) has just fitted some very nice discs to his 4 motion and I fitted a set of Pagid discs and pads to the front of mine before the Ring trip and it only come to £107.Oh and welcome to another 4 motion owner.... Link to post Share on other sites
b road blaster 0 Posted May 1, 2010 Report Share Posted May 1, 2010 as above realy rust on the vented area is not a prob but if the discs are lipped then yes look at changeing them and better stopping power is allways a good thing as for costs well can be done quite cheap or mega money all depends on how good you need them to be Link to post Share on other sites
xyber 1 Posted May 1, 2010 Report Share Posted May 1, 2010 Measure the disk thickness and see if they are under limit Link to post Share on other sites
void_main 0 Posted May 1, 2010 Author Report Share Posted May 1, 2010 Thanks for all the replys.I think, basically my front disks are in fairly good condition, the rear ones I'm not too sure about, heres a pic:You should be able to see a bit of scoring on the disk and a small lip on the edge. Link to post Share on other sites
b road blaster 0 Posted May 1, 2010 Report Share Posted May 1, 2010 yep looks like quite a large lip to me mate thing is unless your gonna upgrade the fronts aswell you might aswell just put standerd ones on imo Link to post Share on other sites
bungy 2 Posted May 1, 2010 Report Share Posted May 1, 2010 If they were mine, i'd replace them. Link to post Share on other sites
void_main 0 Posted May 2, 2010 Author Report Share Posted May 2, 2010 Cheers guys, I've come to the same conculsion now that you've said it too.b blaster, you make an excellent point, no point upgrading the rear without the fronts. I think actually the fronts are already upgraded to the TT disks, I've got some invoices from the previous owner. Will check it out! Link to post Share on other sites
b road blaster 0 Posted May 2, 2010 Report Share Posted May 2, 2010 cheapest option then would be too put new standerd discs on the rear and just upgrade the pads all round to a good compound Link to post Share on other sites
RAPgolfvr6182 2 Posted May 2, 2010 Report Share Posted May 2, 2010 i just my new brakes from gsf £19+ vat each for brembo disks £19+vat for wheel bearings and £37 quid for ebc greenstuff pads Link to post Share on other sites
void_main 0 Posted May 6, 2010 Author Report Share Posted May 6, 2010 I've been doing a little research on those EBC pads you mentioned, they say in the blurb that they are not suitable for 4WD cars... I might be tempted by the 'red stuff' pads though, especially if it means I don't have to clean my alloys as often! Link to post Share on other sites
RAPgolfvr6182 2 Posted May 6, 2010 Report Share Posted May 6, 2010 if you become a premium member on here you get a discount at ebc direct on brake pads and discs, also get a load more discount schemes with other companys, and get access to the knowledge vault with technical write ups etc, well worth the £15 membership Link to post Share on other sites
