It seems our OBD2 VR is suffering from a rather bad misfire. It seems to be evident at idle and part throttle, but goes away under WOT. I've checked for DTCs with VAG-COM but only have one for a 02 sensor having no signal (00525 O2 Sensor). I was expecting at least to see a problem with the coilpack.
I've taken the top plastic covers off that sits over the Coilpack and had a look for any obvious cracking on the top and sides, but nothing obvious, but I would expect the misfire to be there under heavy load/WOT if it were a cracked coilpack and indeed to have the MIL illuminated on the dash.
Would a faulty 02 sensor really cause it to misfire? I would think it would just not use closed loop fuelling??
Help ;(
I did wonder if the signal from the 02 sensor wasn't good, it would'nt run in closed loop fuelling (idle/part throttle). The problem seems to go away at WOT.
I've whipped the spark plugs out yesterday. Cyl 1,2 and 6 had a white deposit on the electrodes and were a little wet (ish), the other 3 looked ok.
Found the cause of the DTC though...just need a new female terminal now....oh and a pin extraction tool...
