spiderman69 0 Posted May 7, 2010 Report Share Posted May 7, 2010 I've just installed a gas flowed throttle body on my 97 highline. I was told it would take a few days to settle down and work out the new flows etc. After a drive from Bournemouth to Leeds and back its still sitting at around 1000 revs and hasn't gone back to its original 900ish revs.Do i need to reset anything on the car or go and get it checked with VAG COM to clear any fault codes?Any help would be appreciated, by the way it goes like stink!Many thanks Link to post Share on other sites
spadam 7 Posted May 7, 2010 Report Share Posted May 7, 2010 If you turn your ignition but dont start the car and leave it for 15mins it will reset. Link to post Share on other sites
craggsy 91 Posted May 7, 2010 Report Share Posted May 7, 2010 VAGCOM can also do a throttle body reset too Link to post Share on other sites
CALICO 130 Posted May 7, 2010 Report Share Posted May 7, 2010 did you fit it yourself is the throttle cable to tight Link to post Share on other sites
binliner 0 Posted May 7, 2010 Report Share Posted May 7, 2010 If you turn your ignition but dont start the car and leave it for 15mins it will reset.What he saidAlthough I don't think you need to leave it that long, if you open the bonnet you'll hear it making noises, when it stops it's done Link to post Share on other sites
Rikki 2 Posted May 7, 2010 Report Share Posted May 7, 2010 3 mins with ignition on 3 mins on idle or vagcom takes about 15 seconds!!! may not cure it tho have you removed the hump in the tb? Link to post Share on other sites
Gazbarber1982 3 Posted May 8, 2010 Report Share Posted May 8, 2010 I've just had my head re-conditioned and new chains, tensioners, etc. fitted and when I went to channel 098, it says apt OK but when I goto basic settings it says adaption error. Its a 96 VR Highline OBDII Link to post Share on other sites
spiderman69 0 Posted May 9, 2010 Author Report Share Posted May 9, 2010 Problem solved! Tried the 3 minute ignition on and then idle for 3 mins, sorted itself right out. Many thanks for the knowledgable advice Link to post Share on other sites
Matt W 4 Posted June 4, 2010 Report Share Posted June 4, 2010 I've just had my head re-conditioned and new chains' date=' tensioners, etc. fitted and when I went to channel 098, it says apt OK but when I goto basic settings it says adaption error. Its a 96 VR Highline OBDII[/quote']I have the same problem, i think its because the stepper motor in my TB is broken.I think a new (or 2nd hand) TB is the only solution. Link to post Share on other sites
