Lukey. 381 Posted May 16, 2010 Report Share Posted May 16, 2010 I decided to track down my very very slight but incessant oil drip that keeps appearing under my car that looked like it was coming from the oil filter area.I had a look under and found it was this bit next to the filter housing, the screw cap was about half a turn loose so ive tightened it up and hopefully thats the end of that.But what is it? Link to post Share on other sites
terrorste 0 Posted May 16, 2010 Report Share Posted May 16, 2010 I'm sure thats the oil cooler. Link to post Share on other sites
legvw 0 Posted May 16, 2010 Report Share Posted May 16, 2010 ^^^^^^Yep, sure is. Link to post Share on other sites
DanH 1 Posted May 16, 2010 Report Share Posted May 16, 2010 was it dripping off the bottom edge of the oil cooler? so was mine so i replaced the seals on it...didnt help so think its the actual body thats got the leak Link to post Share on other sites
gwillhulk 0 Posted May 16, 2010 Report Share Posted May 16, 2010 mines pissing out from here but it looks like its coming from the top, thanks for answering what it is tho. If its just the seals it should be easy to fix and are they easy to get, i.e. your local auto parts shop plus could it be anythin major other than seals?cheers all... Link to post Share on other sites
DanH 1 Posted May 16, 2010 Report Share Posted May 16, 2010 yea gsf or whoever.....jus like 2 o-rings. basterd to get to tho! especially if u have aircon! Link to post Share on other sites
Lukey. 381 Posted May 16, 2010 Author Report Share Posted May 16, 2010 yea it was dripping from the bottom edge but dont know if it was the bottom edge just cos of gravity Link to post Share on other sites
DanH 1 Posted May 16, 2010 Report Share Posted May 16, 2010 can try the 2 seals then, should do it. gotta replace the whole thing on mine now i think tho. its my last oil leak to sort tho! Link to post Share on other sites
gwillhulk 0 Posted May 16, 2010 Report Share Posted May 16, 2010 yeah think i'll do that then, hopefully thats the last leak to... Link to post Share on other sites
thegoth 5 Posted May 16, 2010 Report Share Posted May 16, 2010 mines pissing out from here but it looks like its coming from the top' date=' thanks for answering what it is tho. If its just the seals it should be easy to fix and are they easy to get, i.e. your local auto parts shop plus could it be anythin major other than seals?cheers all...[/quote']the front and back seals are different. when I replaced my cooler about two years ago I got it from GSF who only did one type of seal. Had to get the other from VW. Link to post Share on other sites
gwillhulk 0 Posted May 17, 2010 Report Share Posted May 17, 2010 the front and back seals are different. when I replaced my cooler about two years ago I got it from GSF who only did one type of seal. Had to get the other from VW. cheers, tbh honest I suspected a trip VW might be needed as i've had this problem befor when it comes to seals and o-ring's.Is it pritty easy to do this job as I don't have a Haynes for a VR6 and come to think about I can't seem to find one. Link to post Share on other sites
ibiza vr6 0 Posted May 23, 2010 Report Share Posted May 23, 2010 when i did my chains mine started to leak so i tuck it off and sealed it with sealer and its not leaked since Link to post Share on other sites
