gwillhulk 0 Posted May 31, 2010 Report Share Posted May 31, 2010 Basicaly, yesterday I started to replace the seals on my oil cooler but come across another problem because some Garage decided to boge the repair instead of replacing it...pffftThe plastic water cooling pipe has been broken at some point and the used glue and sealent tp fix it, so i'm now looking to buy a new coolent pipe. Does anyone know if VW sells these as its the only bit I need... Link to post Share on other sites
m4t7y 0 Posted May 31, 2010 Report Share Posted May 31, 2010 Which 1? Part number? I have a full set and only need one of them. Link to post Share on other sites
gwillhulk 0 Posted May 31, 2010 Author Report Share Posted May 31, 2010 Which 1? Part number? I have a full set and only need one of them.I need the plastic pipe thats above the oil cooler and filter (center of the front end photo), that goes into the thermostate housing...cheers fella, i don't know the part number sorry. Link to post Share on other sites
jimmyb 2 Posted May 31, 2010 Report Share Posted May 31, 2010 ive just had a look mate i thought i had a crack pipe lying about but i cant find it if i do i will let u know Link to post Share on other sites
Ben Seabrook 4 Posted May 31, 2010 Report Share Posted May 31, 2010 crack pipe part number is 021121050C mate Link to post Share on other sites
golfrabbit33 0 Posted May 31, 2010 Report Share Posted May 31, 2010 c2 motorsport sell a stainless one, no cracks or breaks to worry about Link to post Share on other sites
gwillhulk 0 Posted June 5, 2010 Author Report Share Posted June 5, 2010 Job done... Decided to replace the whole thermo (inc.all plastic's) set as when I took it all off the thermo-stat was a bit buggerd lol.anyway no leaks, crackes and all done right with no bodging... Link to post Share on other sites
cragus 0 Posted June 5, 2010 Report Share Posted June 5, 2010 Which 1? Part number? I have a full set and only need one of them.Dude have you got the one that leads from the thermo housing and goes up to the bottle and somewhere round the back? Mine split the other day and ive bodged it so wouldnt mind replacing it. Link to post Share on other sites
gwillhulk 0 Posted June 5, 2010 Author Report Share Posted June 5, 2010 Which 1? Part number? I have a full set and only need one of them.Dude have you got the one that leads from the thermo housing and goes up to the bottle and somewhere round the back? Mine split the other day and ive bodged it so wouldnt mind replacing it.no sorry fella, the plastic pipes i took off where buggerd and luckely enough my rubber pipes where ok after i cleaned the ends up. Link to post Share on other sites
xyber 1 Posted June 5, 2010 Report Share Posted June 5, 2010 Is that red silicone sealer around the heat exchanger cap? BODGE!!!!! :-) Link to post Share on other sites
DanH 1 Posted June 5, 2010 Report Share Posted June 5, 2010 sorry to jump in here, but wot is that cylinder thing with the pipe out the top and open at the other end? under the air filter and to the left of the chassis leg? i was told its to do with aircon, but see ur car doesnt have it so i think he was guessing :Sjus curious! cheers, dan Link to post Share on other sites
xyber 1 Posted June 5, 2010 Report Share Posted June 5, 2010 Air con condensor mate Link to post Share on other sites
gwillhulk 0 Posted June 5, 2010 Author Report Share Posted June 5, 2010 yeah mine doesn't have AC fella. Link to post Share on other sites
gwillhulk 0 Posted July 9, 2010 Author Report Share Posted July 9, 2010 Is that red silicone sealer around the heat exchanger cap? BODGE!!!!! I know what your saying but it aint, I bought the two new o-rings for the oil cooler and put this way i'm the over engineering type person I always like to make sure the job is done right. so I used red sealent to make sure it will never leak again< and guess what so far it aint lol.... Link to post Share on other sites
Lukey. 381 Posted July 11, 2010 Report Share Posted July 11, 2010 the black cylinder under the air filter to the left of chassis leg is the carbon cannister isnt it? Link to post Share on other sites
squid1 0 Posted July 11, 2010 Report Share Posted July 11, 2010 yer its on all model for 14 to vr6's and u can remove it tho but need need to block a pipe up Link to post Share on other sites
