Basicaly, yesterday I started to replace the seals on my oil cooler but come across another problem because some Garage decided to boge the repair instead of replacing it...pffft
The plastic water cooling pipe has been broken at some point and the used glue and sealent tp fix it, so i'm now looking to buy a new coolent pipe. Does anyone know if VW sells these as its the only bit I need...
Which 1? Part number? I have a full set and only need one of them.
I need the plastic pipe thats above the oil cooler and filter (center of the front end photo), that goes into the thermostate housing...
cheers fella, i don't know the part number sorry.
Dude have you got the one that leads from the thermo housing and goes up to the bottle and somewhere round the back? Mine split the other day and ive bodged it so wouldnt mind replacing it.
no sorry fella, the plastic pipes i took off where buggerd and luckely enough my rubber pipes where ok after i cleaned the ends up.
sorry to jump in here, but wot is that cylinder thing with the pipe out the top and open at the other end? under the air filter and to the left of the chassis leg? i was told its to do with aircon, but see ur car doesnt have it so i think he was guessing :S
jus curious! cheers, dan
  • 1 month later...
Is that red silicone sealer around the heat exchanger cap? BODGE!!!!!
I know what your saying but it aint, I bought the two new o-rings for the oil cooler and put this way i'm the over engineering type person I always like to make sure the job is done right. so I used red sealent to make sure it will never leak again< and guess what so far it aint lol....
