cornishvr6 52 Posted August 8, 2012 Author Report Share Posted August 8, 2012 good luck Mark and nice plate Thanks Helen, really happy with the plate. Hopefully luck will be on my side but just going to take my time with this and get it exactly how i want it Link to post Share on other sites
cornishvr6 52 Posted August 16, 2012 Author Report Share Posted August 16, 2012 Today i started stripping the engine down to a bare block, all hoses off, inlet manifold off, alternator, oil cooler, oil filter housing, thermostat housing, crack pipe, air con compressor etc etc and this is what i was left with.Inlet manifold getting prepped ready for primer, need some finer grit paper to get some fine scratches out before it gets a full coat of primer.Whilst i was doing all this in the other corner of our barn my mate was working on his vr,Then started cleaning the block up, happy with how its scrubbing up at the moment Link to post Share on other sites
Lukey. 381 Posted August 16, 2012 Report Share Posted August 16, 2012 Wicked make sure you do a really detailed step by step so if I ever come to doing the conversion myself I can do it really easy lol Link to post Share on other sites
cornishvr6 52 Posted August 17, 2012 Author Report Share Posted August 17, 2012 Wicked make sure you do a really detailed step by step so if I ever come to doing the conversion myself I can do it really easy lolI will try mate, with plenty of pics along the way... Link to post Share on other sites
Vw_owner 1 Posted September 4, 2012 Report Share Posted September 4, 2012 looking good m8, wouldnt mind a peice of the 3.2 myself if you need someone to sort out your wireing then this guy comes highly recomended, knows his stuff! http://www.clubgti.com/showthread.php?234432-Rubtechwerke-wiring-services! Link to post Share on other sites
VIW28 29 Posted September 4, 2012 Report Share Posted September 4, 2012 That engine cleaned up really well! My 24 unit was minging! lol Link to post Share on other sites
cornishvr6 52 Posted September 4, 2012 Author Report Share Posted September 4, 2012 That engine cleaned up really well! My 24 unit was minging! lolcheers i thought so too, alot easier than trying to clean the many years of crud on the 12v, looks even better now its painted. need to get some updated pics up. Link to post Share on other sites
cornishvr6 52 Posted September 4, 2012 Author Report Share Posted September 4, 2012 Had my last drive this evening up to the unit :-( Started stripping it down, front end off, coolant dropped, samco's off and to there new owner (in the same unit) All set for a full day on it tomorrow and have it ready for the engine to be removed hopefully. Link to post Share on other sites
cornishvr6 52 Posted September 11, 2012 Author Report Share Posted September 11, 2012 Engine now out this evening, Plans for tomorrow are remove dash to release the remainder of the original loom/fusebox, Pick up a new front engine bracket, Also need to look into new mounts, original or uprated solid versions im unsure yet. Link to post Share on other sites
lumoxs 0 Posted September 12, 2012 Report Share Posted September 12, 2012 keeping my eye on this sonnie Link to post Share on other sites
VIW28 29 Posted September 12, 2012 Report Share Posted September 12, 2012 Good work, now the fun begins Link to post Share on other sites
cornishvr6 52 Posted October 2, 2012 Author Report Share Posted October 2, 2012 Ok so finally found my card reader so here is some updates and plenty of pics of what has been done the past week or so.Car stripped down with parts removed ready for engine removalEngine out, Manifolds,Downpipes, Exhaust, Engine to fusebox loom removed along with everything else to de clutter the engine bay.This is part of the obd1 engine to fusebox loom which will be sent away with the mk5 looms to be made into a custom plug and play loom.Then set to work of cleaning the many years of road grime from inside the engine bay and components, Quite happy with how well it cleaned up especially the subframe and steering rack etc.purchased a new rear engine mount and gearbox mount New rear Engine mount fittedSeperated the Vr gearbox, and flywheel from the old block, Set to work cleaning it up which took forever, Then gave it a coat of VHT Silver/Grey paint, still unsure on the colour at the moment may stick with it or go with Gloss black engine enamel instead, also fitted a new reverse switch and will be painting the weight in black.Draft Designs 24v s/s water pipe (crack pipe) in wrinkle black fittedEngine Hoist brackets painted in VHT SilverEngine block cleaned, Degreased and painted in black enamel, Rocker cover i just had a light blow over with to freshen it up, unsure if im going to get it polished or powdercoated at the momentGolf mk4 v6 4motion alternator bracket painted up ready to be fitted to the block Link to post Share on other sites
cornishvr6 52 Posted October 2, 2012 Author Report Share Posted October 2, 2012 Then the task of cleaning the chassis legs up, cutting any unwanted lugs from the bay that are no longer required, Removing the vw sealant and rubbing down prior to a spot of smoothing which should be starting very soon hopefully.Engine and gearbox as they stand at the moment, Just awaiting a new Sachs clutch kit so i can get the gearbox bolted up to the engine.Ordered a set of Powerflex subframe bushes which should be here tomorrow then once i get a new front engine mount and bracket i should be looking good for a trial fit in the coming weeks if it all goes to plan. Also got the remaining part of the mk5 R32 loom i have been on the hunt for (full interior/fusebox loom) from a nice chap over on the R32OC so that will also be ready so i can send away with the other looms to be made in to a custom plug and play item Link to post Share on other sites
VIW28 29 Posted October 3, 2012 Report Share Posted October 3, 2012 Nice progress, the rest shouldnt take too long now! Link to post Share on other sites
craggsy 91 Posted October 3, 2012 Report Share Posted October 3, 2012 Nice progress' date=' the rest [b']shouldnt take too long now!That's funny coming from the man who's taking sooooo long to get his done lol michael5556 1 Link to post Share on other sites
CALICO 130 Posted October 3, 2012 Report Share Posted October 3, 2012 Pot and Kettle spring to mind . Link to post Share on other sites
VIW28 29 Posted October 4, 2012 Report Share Posted October 4, 2012 Nice progress' date=' the rest [b']shouldnt take too long now!That's funny coming from the man who's taking sooooo long to get his done lolVery true but if mine had been N/A it would have been on the road three months ago! LOL! Link to post Share on other sites
michael5556 247 Posted October 4, 2012 Report Share Posted October 4, 2012 Looking pretty good! Link to post Share on other sites
cornishvr6 52 Posted November 10, 2012 Author Report Share Posted November 10, 2012 I should really update this thread with some progress and pictures once I have uploaded them, as it stands the engine bay has been smoothed, not fully but just the chassis legs and inner wing areas I'm just in the final stages of sanding down which has takinsoapot of hours in the past couple of weeks, hoping to get some primer on soon and a few coats of paint. Also what's been happening this week as follows -Purchased 3.2 ecu which arrived todaySent all my looms away to have a custom vr6/r32 loom createdClutch kit and new front engine mount arrivedParcel of new bolts/washers from vw arrived for flywheel, clutch, engine bay etc Link to post Share on other sites
cornishvr6 52 Posted November 10, 2012 Author Report Share Posted November 10, 2012 I should really update this thread with some progress and pictures once I have uploaded them, as it stands the engine bay has been smoothed, not fully but just the chassis legs and inner wing areas I'm just in the final stages of sanding down which has taken alot of hours in the past couple of weeks, hoping to get some primer on soon and a few coats of paint. Also what's been happening this week as follows -Purchased 3.2 ecu which arrived todaySent all my looms away to have a custom vr6/r32 loom createdClutch kit and new front engine mount arrivedParcel of new bolts/washers from vw arrived for flywheel, clutch, engine bay etc Link to post Share on other sites
VIW28 29 Posted November 11, 2012 Report Share Posted November 11, 2012 Who's doing your looms buddy? Link to post Share on other sites
cornishvr6 52 Posted November 11, 2012 Author Report Share Posted November 11, 2012 Who's doing your looms buddy?Looms are being made by rubjonny off clubgti, mk1oc, edition 38 etc, comes highly recommended and knows his shizzle, very helpful guy. Link to post Share on other sites
VIW28 29 Posted November 11, 2012 Report Share Posted November 11, 2012 Nice one Link to post Share on other sites
Lukey. 381 Posted November 11, 2012 Report Share Posted November 11, 2012 Good choice he knows everything I would use him if I ever needed anything done that I couldn't do myself. Link to post Share on other sites
craggsy 91 Posted November 11, 2012 Report Share Posted November 11, 2012 What Jonny doesnt know about VW electrics isnt worth knowing lol Link to post Share on other sites
