DreadedDev 0 Posted June 2, 2010 Report Share Posted June 2, 2010 Just brought myself a set of Ramps of E-bay, that are actually wide enought for 205 tyres (most of them are only 200mm wide).... got them home, tried to drive up but that front splitter just keeps catching and bending under.... has anyone come up with a safe way of using standard ramps with their VR6. I don't "think" mine is lowered... but that splitter is pretty low!! I need to get under there and brought the ramps to make it easy.... chance would be a fine thing!!!Are the splitters removable (easily and without damage?) Link to post Share on other sites
VR6Nat 9 Posted June 2, 2010 Report Share Posted June 2, 2010 most splitters can just pull off, you may have a screw that attaches the inner arch to the splitter but once they're off both sides it just pulls off.... :) Link to post Share on other sites
RAPgolfvr6182 2 Posted June 2, 2010 Report Share Posted June 2, 2010 as nat said splitter un clips if its to much to do i use 2 slabs i drive on them n them up ramps and dont get caught on the spliter Link to post Share on other sites
LadVR 0 Posted June 2, 2010 Report Share Posted June 2, 2010 Just brought myself a set of Ramps of E-bay' date=' that are actually wide enought for 205 tyres (most of them are only 200mm wide).... got them home, tried to drive up but that front splitter just keeps catching and bending under.... has anyone come up with a safe way of using standard ramps with their VR6. I don't "think" mine is lowered... but that splitter is pretty low!! I need to get under there and brought the ramps to make it easy.... chance would be a fine thing!!!Are the splitters removable (easily and without damage?)[/quote']I use different lengths of scaffold planks to step the car up to the ramps if you get what I mean, my mk2 front splitter will just clear a board with a few mm to spare, should be enough to lift the front up on yours mate Link to post Share on other sites
Gazbarber1982 3 Posted June 4, 2010 Report Share Posted June 4, 2010 On mine there is x2 7mm screws on each corner of the splitter underneath. Take them out then give the spltter a good pull from the middle. Link to post Share on other sites
