andynick69 0 Posted June 5, 2010 Report Share Posted June 5, 2010 How difficult is it to change coolant and gearbox oil,any guidance appreciated,ta andy. Link to post Share on other sites
AJmk2 2 Posted June 5, 2010 Report Share Posted June 5, 2010 For coolant change on my car i undo the lower radiator hose and let it all drain out that way into a bucket. Then just put the hose back on and refill it.Not sure about gearbox Link to post Share on other sites
DanH 1 Posted June 5, 2010 Report Share Posted June 5, 2010 gearbox, underneith, lowest part of the box, where the diff is housed is the drain plug. its a 17 or 19mm allen key u'll need -cant remeber which one. filler is half way up on the back of the box, which faces front of car.hope that makes sense lol! Link to post Share on other sites
andynick69 0 Posted June 5, 2010 Author Report Share Posted June 5, 2010 Does car need to be raised then for the gearbox oil?? Link to post Share on other sites
DanH 1 Posted June 5, 2010 Report Share Posted June 5, 2010 never done it lol but id say yea, give urself a bit of room. jack it up a bit Link to post Share on other sites
squid1 0 Posted June 5, 2010 Report Share Posted June 5, 2010 i done mine its easy to jack up the front of the car for the main reson u get more u get more oil out that way fella Link to post Share on other sites
james4287 1 Posted June 6, 2010 Report Share Posted June 6, 2010 how often should gearbox oil be replaced? Link to post Share on other sites
vr6_super 0 Posted October 13, 2010 Report Share Posted October 13, 2010 bump, i wouldnt mind knowing this either. ive done 3000 miles since mot in february and got the car previous september. havent changed anything in it but wondering if i should do everything at once.like gearbox oil, engine oil, coolant etc Link to post Share on other sites
VR6Nat 9 Posted October 13, 2010 Report Share Posted October 13, 2010 engine oil should be done a minimum of every 10k but i do mine every 5k (or 6 months, whichever comes sooner)gearbox oil doesnt have a set time, i did mine 3k ago but im sure it had never been done, lol. its always nice to do it so you know its fresh, but once its done once i wouldnt worry.... same with coolant, just give it a change once a year or 2 years to flush out any s**t, that should do ya. :) Link to post Share on other sites
Lukey. 381 Posted October 13, 2010 Report Share Posted October 13, 2010 you can change the gear oil by just driving the front wheels onto blocks, you dont need much of an angle to drain the box. its a 17mm allen key socket bolt. make sure you clean all the swarf out of both plugs as they are magnetic. There shouldnt be much on them but best to get it out and not circulating in the new gear oil. i would get a piece of clear hose and a funnel to fill up makes it miles easier. Link to post Share on other sites
vr6_super 0 Posted October 13, 2010 Report Share Posted October 13, 2010 cheers, sods law had a job at a garage today and he said gearbox oil only really needs done after 100k really or when the box decides to call it a day loland may as well do the oil and coolant for the winter, give her a wee treat considering all the punishment she gets loltho really need to get her on a dyno coz last night pushed a vr32 which is around the 250 mark, on the level with a push i had against a 260bhp cupra the other month, defo standard but shes got guts Link to post Share on other sites
