VR6-DUB 3 Posted August 6, 2010 Report Share Posted August 6, 2010 Have not had the chance to spray top mounts yet but managed to spray silicone spray with a straw between the gap of the rear tyres and arch and just sprayed the complete rear coilovers.When you open the boot and bounce the car up and down is when when you can here the noise same as when you are driveing. Link to post Share on other sites
richierich37 236 Posted August 6, 2010 Author Report Share Posted August 6, 2010 When you open the boot and bounce the car up and down is when when you can here the noise same as when you are driveing.dude its the rubber things creaking against the metal......................go in your boot and remove the rubber covers at the top of the coilover (just under the parcel shelf).....................spray the silicone in there then bounce the rear up and down holding the bumper/boot area!repeat as ness!mine only creaks for about the first 30 seconds of driving then it goes away!good luck! lol (h) Link to post Share on other sites
Gazbarber1982 3 Posted August 6, 2010 Report Share Posted August 6, 2010 where did you get them from? My old coilies are shot and the only jamex kists i can find have coilovers for the front and traditional springs and struts for the back.http://cgi.ebay.co.uk/JAMEX-VW-GOLF-MK3-91-07-COILOVER-LOWERING-KIT-/160362809777?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item25565e49b1I've got these fitted to my current VR and thet are s**t!! I'been round a slight bend on the M60 near me and 'bounced' accross all 3 lanes! () I have the JOM coilovers off my other VR and \I'm seriously looking at fitting these. Maybe the shockers are worn on the jamex but I was assured they were "£1000 coilovers when they were new" only to discover they're the cheapest on the market!!Steer clear of the jamex if I was you. Link to post Share on other sites
Craig77 0 Posted August 18, 2010 Report Share Posted August 18, 2010 Ive got these on my MK3 Gti! I had knocking issues until I found that the top strut bolt had come loose that clamps the spacer in!tighten everything up!also get some one to load the rear suspension up !Ie pull off in first with handbrake up!and check if the exhaust box is hitting the rear axle!interesting comment abt how pooo these are!Iam concerned as Ill be converting my Gti to a VR6 and wonder if thew will be ok? Link to post Share on other sites
VR6Gill 1 Posted August 18, 2010 Report Share Posted August 18, 2010 I have Jom sets for sale £160 delivered. Link to post Share on other sites
VR6-DUB 3 Posted August 27, 2010 Report Share Posted August 27, 2010 Still suffering from that worrible creaking noise, might have to get it looked at, mayber rubber mounts and bearings need changing? Link to post Share on other sites
gavinvr6 0 Posted August 27, 2010 Report Share Posted August 27, 2010 did you use new top mounts when you fitted the coilies? creaking sounds like the rubber rubbing against the metal, it could actually be the bushing for the rear beam twisting and making the noise and just transmitting the sound up the leg into the boot making it sound like it's coming from the struts. if you remove the caps from the top of the struts and bounce the car quite vigorously there should be zero movement to the strut top if it is moving it may need either tightening slightly to take out he play or new top mounts. rear's are a peaice of piss to do. less than an hour to do both side's if you dont snap the shock lower bolt like i did lol Link to post Share on other sites
VR6-DUB 3 Posted August 28, 2010 Report Share Posted August 28, 2010 I am in the process right know in getting part numbers for the top mounts and bearings, neva thought of changing them, but will do soon. I am 100% sure that horrible noise was not there before i had my coillies fitted straight after fitting the coilies that noise started coming through, especially when driving at low speeds and goig over speed humps. Nice 1 gavin appreciate it mate. Link to post Share on other sites
