muttley 0 Posted June 12, 2010 Report Share Posted June 12, 2010 hi guys i'm going to be using a Vento vr6 as my doner car, i already have the whole car in the garage with a obd1 engine and all running gear, well the whole car lolI've just been chatting to a guy who is breaking two corrado 16v's and have ordered the following list of parts off himRear axelradiatorcross memberpedal boxand a subframe but i'm not really sure if i need this :? is there anything else i should be getting? Link to post Share on other sites
AJmk2 2 Posted June 12, 2010 Report Share Posted June 12, 2010 Im not sure on the swap parts between the corrado but pretty sure there is a list on the net somewhere.Im pretty sure you can swap over the complete front subframes with the mk3 but you will have a slightly wider track so may need to roll your arches out a bit.Also with my car im pretty sure im running corrado shocks to better compensate with the extra weight over the front axel which the mk2 dampers wont be set for. Good luck with the conversion Link to post Share on other sites
Miggs2002 0 Posted July 22, 2010 Report Share Posted July 22, 2010 the corrado is the best car to use as the donor because all the parts minus the rear engine subframe will go straight into the mk2, the pedal box clutch master cylinder radiator and top and bottom rad hoses are the most important things from the raddo Link to post Share on other sites
muttley 0 Posted July 30, 2010 Author Report Share Posted July 30, 2010 can i stick to my 4 stuid wheels and mk2 track width, if i do how do i do it? Link to post Share on other sites
GVK 1 Posted August 5, 2010 Report Share Posted August 5, 2010 use your existing mk2 bottom arms (wishbones) in the mk3/corrado subframe. Link to post Share on other sites
muttley 0 Posted August 6, 2010 Author Report Share Posted August 6, 2010 if i do that, will i have to cut down the vr6 drive shafts or do use the gti ones?also i've heard there is a conversion to change the hydrolic change gearbox over to a cable change. so in turn not having to use a corrado pedal box and cutting a hole in the bulkhead. i've heard its a part that the Seat torledo uses,has anyone heard of this? Link to post Share on other sites
colwan 0 Posted August 18, 2010 Report Share Posted August 18, 2010 Dont forget to drill the rear legs on the subfraim thay are slightley longer on the VR6 and wont match your floor pan! Its much easyer to do off the car trust me i know!! Link to post Share on other sites
muttley 0 Posted August 18, 2010 Author Report Share Posted August 18, 2010 Dont forget to drill the rear legs on the subfraim thay are slightley longer on the VR6 and wont match your floor pan! Its much easyer to do off the car trust me i know!!is there a guide on how to do this or do u have any photo's of what you did laying around somewhere? Link to post Share on other sites
Andyaus 0 Posted August 29, 2010 Report Share Posted August 29, 2010 Hi,I have just completed a mk2 vr6 and i had the whole mk3, i used the mk3 subframe and rear beam, wide tracked it but kept 5 stud as i wante the 288mm brakes. I also went with the corrado pedal box and clutch master, cutting a hole in the bulkhead was easy enough. Link to post Share on other sites
muttley 0 Posted August 30, 2010 Author Report Share Posted August 30, 2010 Hi' date='I have just completed a mk2 vr6 and i had the whole mk3, i used the mk3 subframe and rear beam, wide tracked it but kept 5 stud as i wante the 288mm brakes. I also went with the corrado pedal box and clutch master, cutting a hole in the bulkhead was easy enough. [/quote']cool this is what i will be doing with mine,how did you do the radiator? did you us a raddo one or the one off the mk3? Link to post Share on other sites
