VDubj 0 Posted June 19, 2010 Report Share Posted June 19, 2010 Having never replaced rear discs or wheel bearings on my golf vr6 i would like to know how easy it is and what tools are required to remove the bearings? Im not a mechanic but am mechanically minded so any advice would be greatThanks :-d Link to post Share on other sites
craggsy 91 Posted June 19, 2010 Report Share Posted June 19, 2010 Change wheel bearings at same time as putting new discs on means you dont have to take old bearing out of disc Link to post Share on other sites
finny 0 Posted June 22, 2010 Report Share Posted June 22, 2010 Yep, buy new wheel bearings (kit) for your new discs.The bolts holding the caliper carrier can be a bitch to undo.Got the nearside ones off after loads of aggro and spraying with wd40 etc. Used a 1/2 drive, reckon 3/8 would snap with the amount of force used with the breaker bar.Make sure your have a good fixing in with 8mm hex bolt, managed to round both carrier bolts on the off side. I hammered in my 1/2 drive bolt but the carrier bolt was well and truley seized. Tried banging in oversized spline bolt but no good. In the end, used a angle grinder to breaker the caliper carrier in half to get the discs out and then angle grind the bolts from discs side. Had replacement carriers anyway.Hopefully a job not to be done again for a long while. Link to post Share on other sites
