VeedubVR 0 Posted December 14, 2010 Report Share Posted December 14, 2010 How do you want them to sit to the arch? got the rears rolled? Link to post Share on other sites
geo7087 11 Posted December 14, 2010 Author Report Share Posted December 14, 2010 Rears are rolled-ish lol, not fully flat if you get me, really wanting it to sat so ive got the wheel edge just poking by a mm or so outside the wheel arch, or even just with the wheel edge lined up with the arch Link to post Share on other sites
geo7087 11 Posted December 17, 2010 Author Report Share Posted December 17, 2010 Only just had a chance to update this as ive been bedridden the past few days... failVento frontFirst off, Vento front. Got this on just in time for a local fire staton event that went on, unfortunately with a late style grille that was a last minute grab as my early grille still hasn't arrived, however ones being sent direct from Germany, should be here next week As soon as it arrives it will be painted and fitted and should look much neater IMOSticker stack?Added a bunch of red and white stickers in pattern to the rear window, as with all sticker i chuck on they probably won't last, but at the minute im really liking it, adds a bit to the rear end, also chucked on a colour coded grommet in the processAmber'sThrew on amber front indicators, still have the smoked items, but think these actual add to the frontEngineDecided after going polished for a bit that id go for a White and Black theme this time around, so i whipped off the inlet manifold and painted it white along with the plastic top coverStripped down (gave it a clean up after this photo)After installing i decided i wanted to re-route the induction if possible to free up the space in the left side of the engine bay to work towards smooth-ness After a bid of fiddling i found out the componants that i was able to remove and managed to sort wiring out so everything functioned and i could route the induction behind the block at the back of the bay, just had to get hold of oil breather that i painted up in white to match up with the other itemsOverall viewSlightly closer upInduction routeIt is close to the manifold but i haven't noticed any change in the drive of the car, i do plan to change the filter for a smaller item in black and paint any stainless sections white, also planning the expanion tank in white too and a re-location of the battery to the bootOverall im dead happy with the result, feel free to express your opinions! Link to post Share on other sites
Ben Seabrook 4 Posted December 17, 2010 Report Share Posted December 17, 2010 looks very very nice mate not 100% on the orange fogs need to see a full on front shot to fully see them but vento front with early will be awesome.Engine bay work looks great too as you said would be slightly nervous about having my air filter there maybe ok at this time of year but in summer you might notice a difference and I hope the pipes are well away from the manifold ?!?strong work though mate, your turning it into a very lovely car Link to post Share on other sites
geo7087 11 Posted December 17, 2010 Author Report Share Posted December 17, 2010 Pipes are well clear, got the air filter itself propped nicely, with the raceland 6-2-1 it sits slightly different so ive got more room, and any electrical wires are cable tied out of the wayif it gets noticable in summer i can always mess about with it, ill see how it goes, its easy enough to change back anywaysive still got my smoked indicators so if i change my mind ill swap right back, and i can't wait for an early grille haha Link to post Share on other sites
spinksy 0 Posted December 17, 2010 Report Share Posted December 17, 2010 im going to fit one of them oil breathers i thinklooks good! Link to post Share on other sites
Ben Seabrook 4 Posted December 17, 2010 Report Share Posted December 17, 2010 is your 6 branch heat wrapped mate ? Link to post Share on other sites
geo7087 11 Posted December 17, 2010 Author Report Share Posted December 17, 2010 Yeah heat wrapped now Link to post Share on other sites
Ben Seabrook 4 Posted December 17, 2010 Report Share Posted December 17, 2010 ah cool well that does keep the temps down a fair bit mate mine melted all the plastic around the ISV after a particuarly long vigorous drive ;) Link to post Share on other sites
VR6Nat 9 Posted December 17, 2010 Report Share Posted December 17, 2010 Lookin really good mate, I'm propa lovin this!! Link to post Share on other sites
cornishvr6 52 Posted December 17, 2010 Report Share Posted December 17, 2010 looking real nice mate, i will have to pop over for a browse Link to post Share on other sites
Caddyslammed 16 Posted December 17, 2010 Report Share Posted December 17, 2010 looking good mate , VR6OC proper representing white Vr's this year , 3dr and 5dr. Link to post Share on other sites
Mk3Jake 0 Posted December 17, 2010 Report Share Posted December 17, 2010 A Very Tidy Example Of What Can Be Done WIth A Bit of Imagination, Really Liking The Colour Schemes...Would Like Some Info On What Needs To Be Added/Removed For The Oil Breather Filter??Thanks Link to post Share on other sites
Pink.teg 0 Posted December 17, 2010 Report Share Posted December 17, 2010 thats nice have a thing for white cars with dark wheels ..... Link to post Share on other sites
geo7087 11 Posted December 17, 2010 Author Report Share Posted December 17, 2010 basically the pipe leading to the oil breather goes to your induction piping, i removed that link from the sensor onwards so only the induction pipe remained, just blanked the hole off with a grommetalso blanket off the small pipe connection that goes to the inlet mani Link to post Share on other sites
spinksy 0 Posted December 17, 2010 Report Share Posted December 17, 2010 i did the same thing with my civic - i find that oil finds its way into the throttle body an engine if not!keep up the good work Link to post Share on other sites
VeedubVR 0 Posted December 17, 2010 Report Share Posted December 17, 2010 Where did you get your early grill? ive been hunting high and low but cant find 1. VW ca get me one but im not paying £130 for a grill! Link to post Share on other sites
geo7087 11 Posted December 18, 2010 Author Report Share Posted December 18, 2010 company called cth tuning on ebay, can also get Venom motorsports own one, can't wait for mine to arrive! Link to post Share on other sites
VeedubVR 0 Posted December 18, 2010 Report Share Posted December 18, 2010 is your early grill badged? Link to post Share on other sites
geo7087 11 Posted December 19, 2010 Author Report Share Posted December 19, 2010 nah debadged Link to post Share on other sites
geo7087 11 Posted December 31, 2010 Author Report Share Posted December 31, 2010 Well the early grille finally arrived! all my exterior decals are now removed, looks much better IMO Link to post Share on other sites
Lukeybabes 0 Posted January 12, 2011 Report Share Posted January 12, 2011 I think it would look better with the earlyer grill. But defo an improvement on the other one Link to post Share on other sites
thrnapster 0 Posted January 24, 2011 Report Share Posted January 24, 2011 love this car, soo clean Link to post Share on other sites
Craig77 0 Posted January 25, 2011 Report Share Posted January 25, 2011 Dude super sweet looking ride!! Link to post Share on other sites
geo7087 11 Posted February 3, 2011 Author Report Share Posted February 3, 2011 Teaser pic until i sort the ride height out.... Link to post Share on other sites
