tez123 0 Posted June 20, 2010 Report Share Posted June 20, 2010 when driving my vr hard, it blows the dipstick out and i am left with lots of oil everywhere...any ideas why? Link to post Share on other sites
UnitedMotorsport 55 Posted June 20, 2010 Report Share Posted June 20, 2010 Excess crank case pressure. Link to post Share on other sites
tez123 0 Posted June 20, 2010 Author Report Share Posted June 20, 2010 thanks for the quick reply, whats the fix for this? Link to post Share on other sites
xyber 1 Posted June 20, 2010 Report Share Posted June 20, 2010 What boost are you running?What exhaust system do you have? Cat, pipe size etcWhat do your plugs look like?Check the head gasketWhat crankcase breather have you got? Standard valve, no valve, etc and check the pipe isn't kinkedHave you knocked the sump?Can you hear any sounds out of the ordinary that started when the dipstick problem did Link to post Share on other sites
tez123 0 Posted June 20, 2010 Author Report Share Posted June 20, 2010 its the vf engineering stage 2 kit which i believe to be 8psi, it has a milteck system with a decat.i may have knocked the sump as it is very low there is no sounds out of the ordinary, on the other points i am not sure as i bought the car with everything already fitted. Link to post Share on other sites
xyber 1 Posted June 20, 2010 Report Share Posted June 20, 2010 Take some pics of the engine bay and post them up. Include a close up of the top left area of the top of the engineI saw in another of your posts your not to happy with the ecu, any running issues? Link to post Share on other sites
tez123 0 Posted June 20, 2010 Author Report Share Posted June 20, 2010 Ok a will try and do it 2moro....I just don't the think the fueling is correct, I would just prefer to have a known and respected company map it, like the ecu I was trying to buy that had been mapped by stealth.Could this problem be the end for the vr engine, its relatively low milage only around 70k Link to post Share on other sites
xyber 1 Posted June 20, 2010 Report Share Posted June 20, 2010 It could be something nasty, but I've also heard of it happening when the wrong oil has been used.More often than not it's the small things that are hardest to spot, when something expensive goes bang when your driving, you tend to know it Link to post Share on other sites
UnitedMotorsport 55 Posted June 21, 2010 Report Share Posted June 21, 2010 Reasons for excessive crank pressure are:You are pressurising the crank case with boost from the supercharger. ie the breather is piped to the pipe from the SC to the throttle bodyBlocked breather: Self explanitory really - The breather path is blocked.Worn piston rings: This will let cylinder pressure "blow" passed the rings into the crank case causing excessive pressure.There are other reasons but they will all happen due to poor tuning, and you will have a noticable misfire. Link to post Share on other sites
tez123 0 Posted June 21, 2010 Author Report Share Posted June 21, 2010 Thanks I will have a check of the breather pipe 2nite. Do you's at c2 offer a mapping service for the charged vr's..mine has been mapped but I would like it looking at and maybe sorted out if there is a problem.At xyber what oil do u recomend? Cheers Link to post Share on other sites
UnitedMotorsport 55 Posted June 21, 2010 Report Share Posted June 21, 2010 Yes we do. Your email has been replied to Link to post Share on other sites
tez123 0 Posted June 21, 2010 Author Report Share Posted June 21, 2010 Many thanks...it hasn't come thru yet shud come thru soon Link to post Share on other sites
xyber 1 Posted June 21, 2010 Report Share Posted June 21, 2010 Vw synta silver oil always seemed best on mine, alot of others went straight thru it Link to post Share on other sites
