spadam 7 Posted May 1, 2011 Report Share Posted May 1, 2011 Turbo is far more exciting imo Link to post Share on other sites
*P3nfold* 0 Posted May 1, 2011 Author Report Share Posted May 1, 2011 Cheers guys hopefully the next team south meet there will be a S/C or turbo VR to take a ride in! Link to post Share on other sites
*P3nfold* 0 Posted May 4, 2011 Author Report Share Posted May 4, 2011 Lots of bits turned up today, this is getting very exciting only bad points areNeuspeed p-flo induction kit - cancelled got a K&N off Jon on the forumOBD2 C2 ECU - sold before I could collect gutted but not to worry there's United Motorsport just around the corner.Still caught between Rotrex or Turbo. My turbo build costs are still around the same price.Wish I could get a better deal on the Rotrex, I should have bought Craigs lol. Link to post Share on other sites
craggsy 91 Posted May 4, 2011 Report Share Posted May 4, 2011 Well you had first option on it...........something will appear, the rotrex did when i bought it.But its a tough call between rotrex and turbo....both will be fun no doubt Link to post Share on other sites
*P3nfold* 0 Posted May 5, 2011 Author Report Share Posted May 5, 2011 Good point craig, Tony did say buy and keep it until you are ready.As you said, I will come up soon. I might just go N/A for now and just sit and wait. Though not sure how long I can keep waiting lol. Link to post Share on other sites
bungy 2 Posted May 5, 2011 Report Share Posted May 5, 2011 It's very hard waiting but you can do some of the prep work while you wait. Link to post Share on other sites
*P3nfold* 0 Posted May 5, 2011 Author Report Share Posted May 5, 2011 Just sorted out a turbo kit for my VR. Will post the details once I get the kit. Link to post Share on other sites
*P3nfold* 0 Posted May 8, 2011 Author Report Share Posted May 8, 2011 Damn there is an issue with the turbo, hopefully this can be sorted soon.Otherwise, Jetex system is on with decat, bloody roars lol.Oh yes Magnex system is up for sale. Link to post Share on other sites
*P3nfold* 0 Posted May 9, 2011 Author Report Share Posted May 9, 2011 Now then, turbo idea has gone to pot. So its back on the Rotrex.There are two many varibles and loads of understanding before I go turbo, I just want to say the guys that have done it hat off you all.I've gone through my shopping list and decided its all a bit too much I think to start with.So bits so far.Schimmel CamsJetex non-resonated 2.5inch exhaust system with Milltex decat6 branch manifold312mm brake conversionARP headbolts8.5.1 head spacerGearbox + LSDK&N cone filter76mm 135 degree silicone hose, need a 75mm to 51mm reducer, then 300mm alloy t-pipe with 25mm spout for the re-circ and a 51mm 90 degree elbow to charger.Still to get the belowBoost gaugeAEM AFR including lamba and gaugeLucas 440cc injectors - Do i really need these to start with?4bar inline fuel pump - Hopefully TonyVR6'sNGK spark plugs - Not sure which ones to buy yet?Re-circulating dump valve - Not sure which spring I need yet?Oil pressure gauge - Do I really need this to start with?Going to get the engine compression tested first to ensure there are no major issues, if all good then its head spacer, new head gasket, arp headbolts and new chains and guides etc...Then I will get the Rotrex DIY kit including either the C30-84 or C30-94 with 6psi pully.I am not after major power to start with but around 280 - 325 bhp would nice progressive torque would be great and an car that keeps its reliability.I will be honest I have never supercharged a car before but its seems alot less complicated that turboing.If anyone has pointers or advise I would appreciate it. Link to post Share on other sites
craggsy 91 Posted May 9, 2011 Report Share Posted May 9, 2011 Well the way I did it Martin was.....312s on as wanted them anywaysAlready had miltek onThen I put charger on, with no gauges or spacer plate and it ran fine.Then I put spacer plate and ARPs on with Tony along with a new head that Tony provided.Then I decatted it.Then gauges went on...well boost gauge and AFR/widebandI had 360cc injectors to go in but bought the R32 before I got to that stage and was running circa 300bhp at that Link to post Share on other sites
craggsy 91 Posted May 9, 2011 Report Share Posted May 9, 2011 Oh and DIY is a peice of cake as well as its pretty much self explanatory....apart from how to mount tensioner on bracket but still easy Link to post Share on other sites
*P3nfold* 0 Posted May 9, 2011 Author Report Share Posted May 9, 2011 Well the way I did it Martin was.....312s on as wanted them anywaysAlready had miltek onThen I put charger on' date=' with no gauges or spacer plate and it ran fine.Then I put spacer plate and ARPs on with Tony along with a new head that Tony provided.Then I decatted it.Then gauges went on...well boost gauge and AFR/widebandI had 360cc injectors to go in but bought the R32 before I got to that stage and was running circa 300bhp at that[/quote']Cheers Craig, I did start to think I am way over doing this.I am thinking of selling the new Schimmel Cams, dont get the gearbox with LSD as its not ready which would allow the chap to still get rid of it soonest and put the money into the Rotrex kit.Otherwise the rest of it is good to go I think. I did think you would respond! Cheers. Link to post Share on other sites
craggsy 91 Posted May 9, 2011 Report Share Posted May 9, 2011 HAd to realy matey.So get spacer on and charge it, as easy as that.Then get it running right, so decat and gauges to help breathing and tell ya whats going on in there.Rest can be done afterwards in stages. If you do the cams then put injectors in so only one mapping session to set it up.And enjoy it!!!!! Link to post Share on other sites
*P3nfold* 0 Posted May 10, 2011 Author Report Share Posted May 10, 2011 Good point Craig, just trying to strike a deal with the suppliers at the moment. Link to post Share on other sites
*P3nfold* 0 Posted May 11, 2011 Author Report Share Posted May 11, 2011 So small update really, K&N cone filter cleaned and oiled, ARP head stud set paid and will be delivered shortly, Jetex system fitted with decat (bloody loud), new tyres fitted (205/45/16) on my 8j's.Ordered an APIRO Stainless Steel, Induction Air Filter Heat Shield to protect the filter under the bumper, and Mikalor W2 Supra Clamps for the exhaust as the ones supplied I really dont like. All from ebay.Its coming on now with the parts etc...dont think the wife is happy with the parts littering the house lol Link to post Share on other sites
*P3nfold* 0 Posted June 19, 2011 Author Report Share Posted June 19, 2011 Another update as its been a whileI got the AEM AFR,Schimmel short runner and HT leads,Gas flowed head is being negotiatedAll I need now is the Rotrex and I am good to go. Looks like this is going to be next year for the Charger.I want to get the paint work sorted and new door sill welded before winter.All the parts that can be fitted will be so all I need to do is bolt the charger on and get a remapOh Polished Schrick is for sale. Link to post Share on other sites
*P3nfold* 0 Posted July 17, 2011 Author Report Share Posted July 17, 2011 312mm Brake Conversion, Powerflex rear beam and front wishbones done, oh an got the exhaust air tight and the cat back on which is nice.Next weekend is the 6 branches and collect the charger.Would like to say thanks to Paul and Matt for there help!! Link to post Share on other sites
*P3nfold* 0 Posted July 18, 2011 Author Report Share Posted July 18, 2011 Changed my EBC red stuff pads back to normal, check out the picture.I am sure this does not look right, centre of the pad is missing a chunk. Link to post Share on other sites
DazzaVR6 2 Posted July 19, 2011 Report Share Posted July 19, 2011 looks like a stone has got wedged in and made its way out. Link to post Share on other sites
*P3nfold* 0 Posted July 19, 2011 Author Report Share Posted July 19, 2011 Hey Dazza,EBC are going to replace them as a good will gesture. They actually thought I did this on purpose. Twats lol.No matter as I am going to sell the new set and get some Ferodo FDS775 and FDS541, once I get some pennies together. Link to post Share on other sites
*P3nfold* 0 Posted July 27, 2011 Author Report Share Posted July 27, 2011 I got the below parts ready for the engine work in a next few weeks.OilOil filterCoolantSump plug washerRocker cover gasketMetal layered head gasketARP head stud kit.I was going to fit a 8.5.1 head spacer but decided against it once I spoke to VF-Engineering department in the states due to running 8psi boost on a stage 2 kit. So the head spacer is for sale if anyone is interested? Link to post Share on other sites
spadam 7 Posted July 27, 2011 Report Share Posted July 27, 2011 Would be wise to fit the headspacer if your doing the headgasket as it will save money as you WILL want more boost in the future. Plus it safeguards your engines and helps prevent detonation. Link to post Share on other sites
*P3nfold* 0 Posted July 27, 2011 Author Report Share Posted July 27, 2011 Hey adam, decided against the headspacer on the current block but on the new one, well a story in progress lol.The Vortech V3 kit arrived today!!!!! I feel like a boy in a candy store. Link to post Share on other sites
*P3nfold* 0 Posted July 28, 2011 Author Report Share Posted July 28, 2011 Picture of the charger, would like to say thanks to Raj @ nstuning top man and thanks for giving me your time. Link to post Share on other sites
*P3nfold* 0 Posted August 1, 2011 Author Report Share Posted August 1, 2011 At last correct AEM AFR has arrived. Just waiting on the gauge holder then its go time. Link to post Share on other sites
