ibiza vr6 0 Posted July 9, 2010 Report Share Posted July 9, 2010 dose any one no how to set timing marks top and bottom with out taking engine out is it TDC and one witch piston ? help please feel strest dropped spanner into sump so that to take out now Link to post Share on other sites
cabrioman 6 Posted July 9, 2010 Report Share Posted July 9, 2010 there are two cut outs in the cams which a plate slides in to and there is a notch in the crank pulley and a mark on the cover or the little tabe on the clutch lines up with the arrow in the cut out in the top of the gearbox Link to post Share on other sites
ibiza vr6 0 Posted July 10, 2010 Author Report Share Posted July 10, 2010 thanks for your help mate was a tooth out must off moved when removeing cam sproket Link to post Share on other sites
