need help with ideas on removing rear caliper mounts??
Few options
Slightly bigger Allen socket, hammered in and then slowly wound out.
Or
Vice grips to get going and then by hand
Either way get loads of wd40 on then overnight
The plastic cup they sit in has a cap to protect them, but bodgers don't put them back on and the bolt heads rust out and round off when you try to get them out. So you want to replace the caps aswell if they're missing
Edit: beaten to it haha
Few options
Slightly bigger Allen socket' date=' hammered in and then slowly wound out.
Or
its the rears mounts he cant get off not the front calipers so no plastic overs .....
I've managed to get my hands on some bolt removers, well I pick them up off my mate tomorrow so hopefully after hammering these on I will be able remove them.
just need to fit new bolts, does any one know the size of these by any chance so I don't have to waste another day and get these tomorrow too. need the allen bolt size, thread size and length... lol cheers...
Did my rear brake discs & bearings a few weeks ago including putting on MK4 calipers.
Rounded the bolts on the off-side and in the end, angle grind the carrier off, to remove the disc as had no decent access to get the bolts out. Had already tried bashing in oversized spline. Obviously had to source a replacement carrier
The repalcement bolt size is M10 x 21mm part Nr N907 294 01 and they cost about £1.50 each from VW. If I had time, I would use some non hex/ allen type bolts - to avoid any future problems.
