Happy harry 0 Posted August 2, 2010 Report Share Posted August 2, 2010 basically went to change gear gear put the clutch pedal down slipped it into 3rd but when i went to come off the clutch the clutch pedal has stayed on the floor. i suspected something was up with the clutch for a while as the car was juddering abit for a while.sounds like its just the cable but will i need a new clutch aswell??also can you get mobile mechanics to come out and fix it? as i cant move it and its so low it isnt getting on a trailor.edit: doesnt have a clutch cable does it! lol so i need a new clutch basically? Link to post Share on other sites
smiffy 0 Posted August 2, 2010 Report Share Posted August 2, 2010 sounds like clutch..can you change gear at all with the engine running? Link to post Share on other sites
Happy harry 0 Posted August 2, 2010 Author Report Share Posted August 2, 2010 sounds like clutch..can you change gear at all with the engine running?nah when i try it just grinds as if the clutch isnt down. Link to post Share on other sites
craggsy 91 Posted August 2, 2010 Report Share Posted August 2, 2010 does the clutch pull up when you pull it up?As they have been known to break at top of the peddle Link to post Share on other sites
b road blaster 0 Posted August 2, 2010 Report Share Posted August 2, 2010 are the mk3's hyd clutch ?????? if so could it be the m/c up the spout and not the clutch Link to post Share on other sites
Happy harry 0 Posted August 2, 2010 Author Report Share Posted August 2, 2010 does the clutch pull up when you pull it up?As they have been known to break at top of the peddleyeh i can pull it back up, but if you push it back down it doesnt spring forward like it should Link to post Share on other sites
craggsy 91 Posted August 2, 2010 Report Share Posted August 2, 2010 have a read of this...sounds like same thinghttp://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?233943.post Link to post Share on other sites
dman78 1 Posted August 2, 2010 Report Share Posted August 2, 2010 could it be his pedal thats broken as this is a common fault,get under your pedals and have a look mate Link to post Share on other sites
craggsy 91 Posted August 2, 2010 Report Share Posted August 2, 2010 Thats why I posted that link as I think its the peddle itself Link to post Share on other sites
Happy harry 0 Posted August 2, 2010 Author Report Share Posted August 2, 2010 have a read of this...sounds like same thinghttp://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?233943.postspot on mate! ur a life saver! ive just found the white clip in the footwell!!!so whats the best action to take? new clip and weld it in? or just buy a new pedal? Link to post Share on other sites
dman78 1 Posted August 2, 2010 Report Share Posted August 2, 2010 soz craggys didnt read that link,tried to be smart but you beat me to it mate Link to post Share on other sites
craggsy 91 Posted August 2, 2010 Report Share Posted August 2, 2010 soz craggys didnt read that link' date='tried to be smart but you beat me to it mate[/quote']LOL i'll let you off...i very rarely look at links either Link to post Share on other sites
dman78 1 Posted August 2, 2010 Report Share Posted August 2, 2010 this happened to me on my a3,i changed the pedal,£25 from audi,dont know how much it is from vw,its a bit fiddly to fit though Link to post Share on other sites
Happy harry 0 Posted August 2, 2010 Author Report Share Posted August 2, 2010 any idea on the VW part number i need!thanks for your help so far guys!!! id still be scratching my balls if it wasnt for you guys lmao! Link to post Share on other sites
Lukey. 381 Posted August 3, 2010 Report Share Posted August 3, 2010 if youre going to take the pedal out anyway you might as well just weld a better plate onto your existing pedal, i did this when it happened to me, the stock pedal as it comes is only spot welded with tiny welds, its an obvious weak point, you only need to make a better job of it and it will never happen again Link to post Share on other sites
Happy harry 0 Posted August 3, 2010 Author Report Share Posted August 3, 2010 if youre going to take the pedal out anyway you might as well just weld a better plate onto your existing pedal' date=' i did this when it happened to me, the stock pedal as it comes is only spot welded with tiny welds, its an obvious weak point, you only need to make a better job of it and it will never happen again[/quote']ok what about the white clip that fell off is it most likely broken? can i re-use it? it didnt actually seem like the white plastic bit was broke anywhere. Link to post Share on other sites
Pearsy47 1 Posted August 3, 2010 Report Share Posted August 3, 2010 its happened to me its only a couple of quid and saves peace of mind and also weld the thing up so its much stronger then what they come out in the factory !! Link to post Share on other sites
Happy harry 0 Posted August 3, 2010 Author Report Share Posted August 3, 2010 its happened to me its only a couple of quid and saves peace of mind and also weld the thing up so its much stronger then what they come out in the factory !! where'd you get yours from? got the part number? Link to post Share on other sites
Pearsy47 1 Posted August 3, 2010 Report Share Posted August 3, 2010 what the plastic bit well i got 2 of them if you want one ?? Link to post Share on other sites
Lukey. 381 Posted August 3, 2010 Report Share Posted August 3, 2010 dont know the part no i just said i needed the plastic clip from the clutch pedal and showed the guy what it was on the etka drawing in vw. like pearsy said they are literally pence. mine was broken in 2, most people say that if it isnt broken you will probably break it trying to get it back on Link to post Share on other sites
Happy harry 0 Posted August 3, 2010 Author Report Share Posted August 3, 2010 ok thanks for the info! how do i get the clutch pedal off? Link to post Share on other sites
Happy harry 0 Posted August 4, 2010 Author Report Share Posted August 4, 2010 sorry guys any ideas? if i get the clutch pedal off can i do the welding and then just put it back in the car? saves me getting it towed to the garage then!and how did you guys remove the clutch pedal? Link to post Share on other sites
Happy harry 0 Posted August 4, 2010 Author Report Share Posted August 4, 2010 what the plastic bit well i got 2 of them if you want one ??missed this post sorry! yeh i'll have one! send me your paypal and how much you want! cheers buddy! Link to post Share on other sites
Pearsy47 1 Posted August 4, 2010 Report Share Posted August 4, 2010 like a pound mate lol not worth much Link to post Share on other sites
