b19drg 0 Posted August 3, 2010 Report Share Posted August 3, 2010 Hi guys , 3 questions if I may 1, what is this bit with the 2 wires on yellow one blue front of engine ??2, why is it covered in oil and leaking oil on the floor ?? 3 , what parts do i need to fix it and can i do it myself ?? Thanks ! Link to post Share on other sites
cabrioman 6 Posted August 3, 2010 Report Share Posted August 3, 2010 oil pressure sensor mate just pop a new one in Link to post Share on other sites
craggsy 91 Posted August 3, 2010 Report Share Posted August 3, 2010 They are you oil pressure sensors....by new ones and bobs a dodgy builder Link to post Share on other sites
ashmk3 0 Posted August 3, 2010 Report Share Posted August 3, 2010 I think it's the oil cooler and oil filter it shouldn't be leaking oil and I amnot sure where to get parts or what parts you'll need other than oil and filter and you could give gsf etc a call. Or someone is breaking a vr on here may be worth finding out what you need and asking them if they will do you a deal? Link to post Share on other sites
craggsy 91 Posted August 3, 2010 Report Share Posted August 3, 2010 Bugger beat me to it Tony lol Link to post Share on other sites
cabrioman 6 Posted August 3, 2010 Report Share Posted August 3, 2010 They are you oil pressure sensors....by new ones and bobs a dodgy builderu snooze u loose ..... lol Link to post Share on other sites
craggsy 91 Posted August 3, 2010 Report Share Posted August 3, 2010 1-1 now lol Link to post Share on other sites
b19drg 0 Posted August 3, 2010 Author Report Share Posted August 3, 2010 Expensive ?? and if i take it of will a load of oil shoot out ? Link to post Share on other sites
craggsy 91 Posted August 3, 2010 Report Share Posted August 3, 2010 nope quite cheap to fix and if you let the oil settle into the sump then no.....it will do if you just turn the engine off and then take em out Link to post Share on other sites
b19drg 0 Posted August 3, 2010 Author Report Share Posted August 3, 2010 do they need seals or will that come with them already ? and do i need to do both or just one ? do i just ask for oil presure sensor ? Link to post Share on other sites
craggsy 91 Posted August 3, 2010 Report Share Posted August 3, 2010 do both whilst your at it.......just ask for both sensors from TPS. and they have seals on em Link to post Share on other sites
b19drg 0 Posted August 3, 2010 Author Report Share Posted August 3, 2010 there both oil yeah and both the same ? Link to post Share on other sites
cabrioman 6 Posted August 3, 2010 Report Share Posted August 3, 2010 one high oil pressure and the other is low oil pressure so they should give the correct ones mate just make sure the put the wires back on the correct sensor ... Link to post Share on other sites
craggsy 91 Posted August 3, 2010 Report Share Posted August 3, 2010 yep....ones high and ones low pressure Link to post Share on other sites
cabrioman 6 Posted August 3, 2010 Report Share Posted August 3, 2010 yep....ones high and ones low pressure2-1 .... lol Link to post Share on other sites
b19drg 0 Posted August 3, 2010 Author Report Share Posted August 3, 2010 Sweet , thanks agin guys , what would i do without you ! Link to post Share on other sites
cabrioman 6 Posted August 3, 2010 Report Share Posted August 3, 2010 spend loads woth a dodgy garage who dont know wot they are doin ??? lol Link to post Share on other sites
craggsy 91 Posted August 3, 2010 Report Share Posted August 3, 2010 028 919 081D068 919 081N 013 811 5 sealing washersMy ETKA is old so they may have changed Link to post Share on other sites
craggsy 91 Posted August 3, 2010 Report Share Posted August 3, 2010 2-2 after giving part numbers lol Link to post Share on other sites
thegoth 5 Posted August 3, 2010 Report Share Posted August 3, 2010 where's the oil temp sender than guys? Link to post Share on other sites
craggsy 91 Posted August 3, 2010 Report Share Posted August 3, 2010 yeah could change that too1H0 919 563 Link to post Share on other sites
cabrioman 6 Posted August 3, 2010 Report Share Posted August 3, 2010 where's the oil temp sender than guys?behind the left hand oil pressure sensor .... bugger 2-2 ... lol Link to post Share on other sites
b19drg 0 Posted August 3, 2010 Author Report Share Posted August 3, 2010 are they all easy to change without having to remove other stuff ? Link to post Share on other sites
CALICO 130 Posted August 3, 2010 Report Share Posted August 3, 2010 yep Link to post Share on other sites
b19drg 0 Posted August 3, 2010 Author Report Share Posted August 3, 2010 Sweet , thanks Roger you coming billing mate ? Link to post Share on other sites
