hi dose any one no any thing about super charger iv been reading a bit i take it u just bolt them on and go ? do they just air in the faster u go the more air they suck ? and last where is the best place to find on second hand ???? thanks for the help peeps
Stage 2 Supercharger Kit (8psi) 280bhp
Replacement charger pulley for increased boost
Stage 2 high capacity Bosch fuel injectors
Replacement serpentine belt
VF race bypass valve
Stage 2 chip
Upgrade from Stage
£700
is this cheap its from TSR PERFORMANCE
its not the engine that the problem its the parts you are buying very cheap etc. Turbo could break causing fragments of it to be sucked into your engine and writting it off. But by all means give it a go and let us all now how you get on.
Yea go for it. You could allways follow jim potters guide he turbo'd his car for under £1000 and he now runs nearly 400bhp. If you are going to fit a turbo make sure you fit a head spacer and new headgasket to lower compresion ratio otherwise it wont last 2mins.
