Hi Guys,
Sorry if this has been posted before, or if it's in the wrong section :( i did do a quick search but couldn't find anything. New to the world of the VR6, bought it for my 21st birthday as a present to myself! lol
Problem is i got the BMC CDA and wasn't aware they are universal and ideally i need a hose to join it up flushly!
I was wondering if any of you knew the bore size of the below hose: **Sorry for the big picture, i stole it off the corrado forum**
[img width=800 height=600]http://www.the-corrado.net/forum/download/file.php?id=49917
Any help will be much appreciated as i would like to keep to my theme and get a white Samco hose, but at £25 a pop i want to get it right!
Picture isn't working! but it's the one in this link :)
Cheers!
cant see a pic? the correct size CDA for a vr6 is the 85-150, which means you would need 85mm hose to connect to it, youd be best to measure yours to make sure it is the same size though, this pic shows you the dimensions
D1=85mm D2=150mm L1=200mm
cant see a pic? the correct size CDA for a vr6 is the 85-150' date=' which means you would need 85mm hose to connect to it, youd be best to measure yours to make sure it is the same size though, this pic shows you the dimensions
[img']http://www.bmcairfilters.com/cgi-bin/Images/Product/CDAStandard.jpg
Some reason the pic isn't working! But yeah that's the info i need!!
Thank you mate, i appreciate it :)
