you should be able to just remove the ashtray and access the bolts, depends if youve got ratchet spanners or not. if not you can get a bigger throw by removing the whole handbrake surround,
disengage and try to make the little bar level so it pulls uniformly
The rear brake calipers clamp on a ratchet type mechanism. So if you pull the handbrake up and down then the caliper will ratchet up, and hopefully hold the car! If this doesn't work, then maybe your pads are too low, or the cables have stretched.
  • 3 months later...
could you let me know if it was the pads that needed changing as my car is doing exactly the same' date=' im yet to adjust the cables so il obvs check that first and try it...thanks
the handbrake mechanism on the rear calipers had seized (common fault on early vr's app)
so i fitted rear calipers and pads from a later vr which worked a treat :)
