Timah89 1 Posted August 13, 2010 Report Share Posted August 13, 2010 anyone any idea where i can buy the t piece adapter required for the sender fo the oil pressure/temp when fitting the Audi VDO gauges in order for both the dial and MAF to work, every page for teh fitting guide says i need one but god knows where to buy one?!?!?!? Link to post Share on other sites
Lukey. 381 Posted August 13, 2010 Report Share Posted August 13, 2010 do you have the relevant vdo sender already? if not you can get a twin terminal sender, it neatens up the install.http://www.merlinmotorsport.co.uk/p13866/T-PIECE-M10-X-1/product_info.html this is what you need if you already have everything Link to post Share on other sites
Timah89 1 Posted August 13, 2010 Author Report Share Posted August 13, 2010 yeah it came with the sender Link to post Share on other sites
Lukey. 381 Posted August 13, 2010 Report Share Posted August 13, 2010 i edited my post with the t piece you would need if you had it already Link to post Share on other sites
Timah89 1 Posted August 13, 2010 Author Report Share Posted August 13, 2010 minted....thanks Link to post Share on other sites
Timah89 1 Posted August 14, 2010 Author Report Share Posted August 14, 2010 all the guides i can find for fitting these dials are not for the VR6 engine, the oil pressure and temp setup is it any different, has anyone else done this and can you advise how to set it up, pics too if poss. I have the dials powered up and ready just need to sort how to set the temp sensor and presure sensor up. Link to post Share on other sites
Lukey. 381 Posted August 14, 2010 Report Share Posted August 14, 2010 they are all on top of the filter housing, you want to T onto the right one (low pressure) as you are looking from the front of the car, the oil temp sensor is behind both the pressure senders Link to post Share on other sites
Timah89 1 Posted August 14, 2010 Author Report Share Posted August 14, 2010 how do i wire in the temperature wire, does it just wire onto the curent sender and wire or di i need to do anything else???sorry, bit confused by it at the moment Link to post Share on other sites
Timah89 1 Posted August 14, 2010 Author Report Share Posted August 14, 2010 this is the pic of the oil filter housing, is anyone able to advise how to wire it all up now?!?!this is the twin pole sensori think i may have it worked out, brain is working like crap at the moment!! So i presume that i take off the right blue pressure sensor wire, unscrew the current sensor and replace it with the twin pole, the blue wire then plugs back on to 1 of the connectors on the twin pole and the vdo sensor plugs on to the other twin pole connector?!?!? please say this is right?!?! Then the t split that i have ordered is similarly done but against the temp sensor which is the back wire on the housing?!?! thanks and apologies for my muppetness........ Link to post Share on other sites
Timah89 1 Posted August 14, 2010 Author Report Share Posted August 14, 2010 updated above post..... Link to post Share on other sites
Lukey. 381 Posted August 15, 2010 Report Share Posted August 15, 2010 correct, replace the blue wired sneder with the twin, you wont need a t for the pressure as youve got the twin pole.however the temp sender looks like it uses a different thread pitch, the T i linked to was whats required for the pressure sender, the temp sender looks like it may be smaller thread Link to post Share on other sites
Timah89 1 Posted August 15, 2010 Author Report Share Posted August 15, 2010 got it all done now, the pressure is working fine and i replaced the VW temp sender for the Audi one that the gauges came with but the temp sender just shoots right up and over 170, surely very incorrect, any ideas why it would be doing this?!? Link to post Share on other sites
Lukey. 381 Posted August 15, 2010 Report Share Posted August 15, 2010 why dont you try it with the golf temp sender? they may work at differen ranges Link to post Share on other sites
Timah89 1 Posted August 15, 2010 Author Report Share Posted August 15, 2010 i'll give it a shot, right bastard changing them though, fingers crossed that works, will have to invest in another sender if not, if that is the problem of course Link to post Share on other sites
Timah89 1 Posted August 15, 2010 Author Report Share Posted August 15, 2010 changed back to the original temp sender and the dial seems to work correctly now, looks like the temp sender was broken from the Audi, will get a new one though as want to run both the MFA reading and the VDO reading and have the t splitter coming tomorow which wasnt realy the cheapest thing to get with the mad postage involved!!! Link to post Share on other sites
Lukey. 381 Posted August 15, 2010 Report Share Posted August 15, 2010 hopefully its the right thread size and pitch then for the temp sender matealthough why would you need both reading the same? id rather have a gauge than the mfa, far handier to glance at Link to post Share on other sites
