99.5 Cold Air intake...Any recommendations?
BMC CDA 85-150 is the preferred weapon of choice for this engine
is the golf 4 vr6 the GTI vr6 in canada? if so searching golf gti on k&n only gives the 1.8t, if you search normal golf then 2.8 it gives some that will fit, so long as the engine layouts are the same, you can download the installation instructions so you could see if it would fit?
