naffa 0 Posted August 21, 2010 Report Share Posted August 21, 2010 Hi guys I know my Galaxy V6 is using oil, approx 1 litre every 200 miles at motorway speeds.I want to do a compression test and when I've done this on previous motors I've removed the HT lead from the coil to the dizzy cap to prevent the car starting on turnover.I have no such lead on this car (obd2) so how can I prevent the car starting when I do the comp test? Link to post Share on other sites
craggsy 91 Posted August 21, 2010 Report Share Posted August 21, 2010 Pull the connector off the coilpack Link to post Share on other sites
naffa 0 Posted August 21, 2010 Author Report Share Posted August 21, 2010 Thanks Craggsy.Can you point me in the direction of the coil pack please? Link to post Share on other sites
craggsy 91 Posted August 21, 2010 Report Share Posted August 21, 2010 on the side of the head to the right as you look at it from front Link to post Share on other sites
Gazbarber1982 3 Posted August 22, 2010 Report Share Posted August 22, 2010 You will need to remove the plastic covers off the inlet manifold to get to the plug. Link to post Share on other sites
Rikki 2 Posted August 22, 2010 Report Share Posted August 22, 2010 Cant you just pull the fuel pump relay or something???? Link to post Share on other sites
Lukey. 381 Posted August 23, 2010 Report Share Posted August 23, 2010 id do both its only under the right hand side plastic cover, comes off with 2 6mm allen screws Link to post Share on other sites
