will a normal mk3 header tank fit a VR6? also temp sender colour?
hi guys just got off the phone to GSF car parts - few easy questions -
they dont stock a golf VR6 header tank, just a normal mk3 one they said. do you know if this will fit my golf vr6??
also my temperature gauge on the clocks wont go above 70. in my thermostat housing i have one blue 2 pin sender and next to it a 4 pin yellow sender. GSF only stock a 2 pin blue sender, is this the one for the temperature gauge on the clocks?
he also said mine shouldnt be a yellow 4 pin sensor, said it should be a brown one.
arent there any header tanks off newer cars that will fit in the same place? ive been trying to find one' date=' reason being the newer style tanks are much more transparent and have the better caps on them
as said above GSF is where i got mine , its a little smaller than the oval VR6 one but it fits to exactly the same mounting points and the plug for temp gauge works fine. I looked for months to try and get an original header tank but they have been updated to the round version , hope this puts this to rest for you all .
