Under drive crank pulley (vr6) ????
So will i get gains out of it...is it worth the $90
here's the description:
*Super Light weight T6061 T-6 Aircraft Grade Billet Aluminum
*Computer CNC Machined For Precision Balance
*5~10 Horsepower Gain
*Dyno-Tested And Prove on Race Track
*Consistent Horsepower Gain at all Engine Speed
this is for a vr6...
thoughts ,comments...
First post under yours says it all.
Really not worth it,
A lightened standard diameter pulley is a different matter. Some MK2 VR6 owners fit them as a matter of course due to the chassis leg clearance problem and they often report good things.
As said, with a lightweight flywheel, you do notice the difference.
You would be amazed how quickly the VR6 spins up with light pullies, light flywheel and the PAS pump disabled.
I am actually looking into a manual steering rack and electric water pump and just run the alternator off the crank.
Really not worth it' date='
PAS pump???
i ordered a complete gruding ( spelling) kit.... all oem size but much lighter, only under drive part is the power steering pump pulley.
I was advised that the crank underdrive will result in my water pump turning slower and creating problems
