yakuza racer 16 Posted August 25, 2010 Report Share Posted August 25, 2010 So will i get gains out of it...is it worth the $90 here's the description: *Super Light weight T6061 T-6 Aircraft Grade Billet Aluminum*Computer CNC Machined For Precision Balance*5~10 Horsepower Gain*Dyno-Tested And Prove on Race Track*Consistent Horsepower Gain at all Engine Speedthis is for a vr6...thoughts ,comments... Link to post Share on other sites
yakuza racer 16 Posted August 25, 2010 Author Report Share Posted August 25, 2010 BUMP!! Link to post Share on other sites
CALICO 130 Posted August 25, 2010 Report Share Posted August 25, 2010 i dont think they give you BHP they just let the engine spin slightly easier as there is less crank weight add a lightened flywheel as well but your idle may not be perfect Link to post Share on other sites
yakuza racer 16 Posted August 25, 2010 Author Report Share Posted August 25, 2010 please read and give some input herehttp://www.vwclub.co.za/phpbb3/viewtopic.php?f=3&t=110429 Link to post Share on other sites
FishWick 21 Posted August 26, 2010 Report Share Posted August 26, 2010 First post under yours says it all.Really not worth it,A lightened standard diameter pulley is a different matter. Some MK2 VR6 owners fit them as a matter of course due to the chassis leg clearance problem and they often report good things.As said, with a lightweight flywheel, you do notice the difference.You would be amazed how quickly the VR6 spins up with light pullies, light flywheel and the PAS pump disabled.I am actually looking into a manual steering rack and electric water pump and just run the alternator off the crank. Link to post Share on other sites
yakuza racer 16 Posted August 26, 2010 Author Report Share Posted August 26, 2010 First post under yours says it all.Really not worth it' date='A lightened standard diameter pulley is a different matter. Some MK2 VR6 owners fit them as a matter of course due to the chassis leg clearance problem and they often report good things.As said, with a lightweight flywheel, you do notice the difference.You would be amazed how quickly the VR6 spins up with light pullies, light flywheel and the PAS pump disabled.I am actually looking into a manual steering rack and electric water pump and just run the alternator off the crank.[/quote']PAS pump???i ordered a complete gruding ( spelling) kit.... all oem size but much lighter, only under drive part is the power steering pump pulley.I was advised that the crank underdrive will result in my water pump turning slower and creating problems Link to post Share on other sites
Lukey. 381 Posted August 26, 2010 Report Share Posted August 26, 2010 PAS = power assisted steering Link to post Share on other sites
CALICO 130 Posted August 26, 2010 Report Share Posted August 26, 2010 http://www.gruvenparts.com/website/cart/cart.php?target=product&product_id=266the ones to have Link to post Share on other sites
yakuza racer 16 Posted August 26, 2010 Author Report Share Posted August 26, 2010 http://www.gruvenparts.com/website/cart/cart.php?target=product&product_id=266the ones to have those are the ones im getting, busy being shipped as we chat;) Link to post Share on other sites
cabrioman 6 Posted August 26, 2010 Report Share Posted August 26, 2010 im runnning a full set of light weight pullies and light flywheel and its revs up so quick and smooth u wouldnt belive it ..... lol but as sadi just th eone is worth it u need the set and flywheel Link to post Share on other sites
FishWick 21 Posted August 27, 2010 Report Share Posted August 27, 2010 I was advised that the crank underdrive will result in my water pump turning slower and creating problemsYeah don't get an under drive pulley set, it will just cause problems.Light pullies in the standard size are fine. Link to post Share on other sites
Antihero1981 8 Posted August 30, 2010 Report Share Posted August 30, 2010 i run the power steering one and i find it easier to turn the steering wheel .......with it being slammed i found the older one caused steering to be a bit heavier...easy to change Link to post Share on other sites
