DrRich 1 Posted August 25, 2010 Report Share Posted August 25, 2010 Hi all,00281 - Vehicle Speed Sensor (G68)03-00 - No SignalThis code comes up on my Mk2 VR6, along with a carbon canister code (it's not connected so not a problem) and occasional "blocked by immobilizer" (chip is still in Mk3 key so have to hold near ignition barrel - sometimes miss!).I think this is the sensor on the gearbox isn't it -not the camshaftor crankshaft sensors; it's not that the engine isn't running - it's OBD2 and it happens after a run sometimes.So what does it do on a manual car? I haven't seen any problem with the speedometer, the power feels OK, it doesn't stall and idles OK (although occasionally when stopping it idles at 800rpm for a few seconds before dropping to normal at 680ish).I've got a spare OBD1 gearbox - will the sensor from that one fit; is it even worth bothering?Cheers for your thoughts... Link to post Share on other sites
