yakuza racer 16 Posted August 26, 2010 Report Share Posted August 26, 2010 Anyone got a guide to fitting these things??got my set of JOM blue coil overs from Gill.... now i need to have them fit. Please help me out Link to post Share on other sites
Lukey. 381 Posted August 26, 2010 Report Share Posted August 26, 2010 if you havent done it recently get yourself a full set of vw top mount bushes and bearings, always best to start from new with suspension, as if they arent recently new theyll have worn.as for fitting its all nuts and bolts easy stuff, the fronts have the top bolt and 2 bolts at the bottom, undo the top bolt first its easier that way, youll need either a big spanner or a special top mount wrench cos you have to counter hold the threaded post to stop it spinning with the nut. Once youve got the shock off fitting is the reverse of removal, youll have to get them cambered up properly.the rears is the same as the fronts except easier as there isnt any camber alignment to worry about, just make sure the bushes are sat correctly, theres a top and bottom one on the back.easy peasy Link to post Share on other sites
VR6-DUB 3 Posted August 26, 2010 Report Share Posted August 26, 2010 Sorry to high jack the thread a bit but i recently fitted coilovers too and did not change the mounts, Luke how much are a set of vw top mounts and bearings? Link to post Share on other sites
yakuza racer 16 Posted August 26, 2010 Author Report Share Posted August 26, 2010 camber alignment...how do i do that... oh thanks for the explanation, also i read on other forums that fitting these incorrectly will result in broken bits and bobs on your suspention...thats why i want a step by sttep guide to doing it.... Link to post Share on other sites
spadam 7 Posted August 26, 2010 Report Share Posted August 26, 2010 Take it to a garage for 4 wheel laser alignment after you have fiited coilovers. Link to post Share on other sites
yakuza racer 16 Posted August 26, 2010 Author Report Share Posted August 26, 2010 will do that.... if it seems so simple then i would like to do it myself, gonna give it a stab sometime tonight and let you hear the results tomorrow..... Link to post Share on other sites
VR6Nat 9 Posted August 26, 2010 Report Share Posted August 26, 2010 step by step guides are one of the premium member benefits, as you are not a premium member you will not be able to see them but it is fairly straight forward, its just having the tool to remove the top nut at the front thats a bit of a bugger.... Link to post Share on other sites
yakuza racer 16 Posted August 26, 2010 Author Report Share Posted August 26, 2010 ok, now show me :-) Link to post Share on other sites
rodney 17 Posted August 26, 2010 Report Share Posted August 26, 2010 dont forget to get cast and camber done as well when getting 4 wheel laser alignment.. Some don't do it as standard so make sure you ask.. Link to post Share on other sites
Lukey. 381 Posted August 26, 2010 Report Share Posted August 26, 2010 cant remember but i think a full set with bearings is about 40 quid, gen vw, dont get cheap sh!te Link to post Share on other sites
