if you havent done it recently get yourself a full set of vw top mount bushes and bearings, always best to start from new with suspension, as if they arent recently new theyll have worn.
as for fitting its all nuts and bolts easy stuff, the fronts have the top bolt and 2 bolts at the bottom, undo the top bolt first its easier that way, youll need either a big spanner or a special top mount wrench cos you have to counter hold the threaded post to stop it spinning with the nut. Once youve got the shock off fitting is the reverse of removal, youll have to get them cambered up properly.
the rears is the same as the fronts except easier as there isnt any camber alignment to worry about, just make sure the bushes are sat correctly, theres a top and bottom one on the back.
easy peasy
step by step guides are one of the premium member benefits, as you are not a premium member you will not be able to see them but it is fairly straight forward, its just having the tool to remove the top nut at the front thats a bit of a bugger....
