dubberjim 0 Posted August 28, 2010 Report Share Posted August 28, 2010 After some help yet again. Just put my engine back in after finaly fixing the oild leak (don't buy after market main crank oil seals).Tidyed up the engine loom even have the rev counter working now, which is nice . However the probelm is the car randomly just stops from time to time, makes no odds if its cold or warm, dosnt seem to get lumpy, just cuts out. it starts again no problem. also happens when im driving it will just judder as if the car has lost all power and bump starts it self. makes no difference if its bummpy road, under load or just cruising happpens is any gear. its a mk2 2.8 from with coil pack. has new leads, plugs and coil. checked the loom before i wrappped it and all seemed fine no bear wires and no oobvious signs of arching anywhere. the car does seem to be running a little ritch but nothing major. any ideas guy as id like to have atleast one weekend out of the car this summer dubberjim Link to post Share on other sites
L3 onp 0 Posted August 28, 2010 Report Share Posted August 28, 2010 vagcom it and see what it comes up with. sounds like crank sensor to me Link to post Share on other sites
dubberjim 0 Posted August 28, 2010 Author Report Share Posted August 28, 2010 only problem is ive not got diagnostics port. anyone have a guild to fitting one to a mk2? ive tried the mk2vr6 forum but noone seems to have one. Link to post Share on other sites
bungy 2 Posted August 28, 2010 Report Share Posted August 28, 2010 Does it sound like it is starved of fuel ie, fuel breather blocked and cutting out? Does it cut out if you let it run on your driveway or does it take quite a while? Link to post Share on other sites
dubberjim 0 Posted August 28, 2010 Author Report Share Posted August 28, 2010 it probably takes a good five mins but can be totaly random. how would i tell if its starved of fuel? and where is the fuel breather to check? cheers Link to post Share on other sites
bungy 2 Posted August 28, 2010 Report Share Posted August 28, 2010 If it will cut out after about 5 mins on your driveway, just run it with the fuel filler cap off and see if it cuts out. If it continues to run then you can source your breather and rectify. Link to post Share on other sites
dubberjim 0 Posted August 28, 2010 Author Report Share Posted August 28, 2010 cool will try that right now Link to post Share on other sites
dubberjim 0 Posted August 28, 2010 Author Report Share Posted August 28, 2010 strange car wouldnt start. the relay that came with the mk3 loom started going mental clicking like mad took it out and swapped it with another one with 53 on it same thing. after a few mins started and is running fine. fuel filler is off now. Link to post Share on other sites
gavinvr6 0 Posted August 28, 2010 Report Share Posted August 28, 2010 did you not use the entire loom when doing the conversion. im in the process of breaking up my mk3 to build a mk2 and will be transfering the entire engine and ignition loom including the 2x2 diagnostics plugs (mines obd1 coi pack). Link to post Share on other sites
dubberjim 0 Posted August 28, 2010 Author Report Share Posted August 28, 2010 well the thing is i didnt have a donner car and its caused me no end of problems i brouht "everything you need to conver your mk2 8v to a vr6" from some one off ebay they were also on a few forums so thought it would be cosha turns out loads of bits were missing and the loom was a right state. i managed to repair the loom all tested and good but it didnt have the port on it. Link to post Share on other sites
bungy 2 Posted August 28, 2010 Report Share Posted August 28, 2010 Is it still cutting out? Link to post Share on other sites
dubberjim 0 Posted August 28, 2010 Author Report Share Posted August 28, 2010 was running fine for 15 mins and besides dipping in revs when the fans cam on nothing just put the cap on to see what happens now Link to post Share on other sites
dubberjim 0 Posted August 28, 2010 Author Report Share Posted August 28, 2010 just put the cap back on and ran for another 10 didnt cut out atall. this is anyoying. Link to post Share on other sites
CALICO 130 Posted August 28, 2010 Report Share Posted August 28, 2010 maybe it was the relay breaking down Link to post Share on other sites
bungy 2 Posted August 28, 2010 Report Share Posted August 28, 2010 At least that is one area discounted and hopefully you've cured the fault. Link to post Share on other sites
dubberjim 0 Posted August 28, 2010 Author Report Share Posted August 28, 2010 not to sure seems to be pretty random think it must be eletrical might take the dash out and give the wires behind a good sorting out Link to post Share on other sites
dubberjim 0 Posted August 29, 2010 Author Report Share Posted August 29, 2010 been tolf it could be my ignition switch breaking down it there a way to check this? Link to post Share on other sites
