Right this weekend I was a good boy and did some servicing bits and whilst I was under there i noticed some coolant leaking from the thing at the end of my crack pipe.. what is it??
Just for clarity... on the right hand side as I stand and look int the engine bay (so thats the passanger side ;) ) you have the crack pipe thast then has a short flex pipe that connects into a pice which is held on by two 5mm shrouded allen bolts.
I seem to have a leak on the bottom side where it connects to the engine... Am I correct in assuming this is the thermostat?
Cheers
Cheers thats what I thought...
I'm not standard as got oil cooler on so has a piece of pipe on from the crack pipe to this thing on the front of the engine...
I recall there are two temperature 'Stats. Anyone know the temp ratings??
Cheers
