paulo810 0 Posted August 30, 2010 Report Share Posted August 30, 2010 Hi all am newbie to this and like the site I Own a 1997 vr6 and have just bought it with blown head gasket so stripped the engine head off found gasket gone and also noticed heat exchanger had gone and cam chain upper guide blade cracked so replaced that as well noted the problem with the car had been going on for a while so to cut a long story short when rebuilt started her up no probs apart from slightly high tick over and difficulty in bleeding water system of air so switched it off , now to the fault tried to restart it but no joy checked spark checked comp all ok so scratched my head for hours and found plugs wet and eventually deasparation set in so i disconnected fuel supply to fuel rail and clamped it and it started connected fuel supply back and it kept running but keeps blowing water out of rad after 10 mins or so could it be impellers on water pump gone also when i switch it off each time it will not fire untill i disconnect fuel supply so do they suffer fuel pressure reg faults or could it be something else please all you guys i need some help on this p.s it is a 2.8l Link to post Share on other sites
chief ka kar 0 Posted August 31, 2010 Report Share Posted August 31, 2010 Did you get your head re-skimmed after replacing the head gasket Link to post Share on other sites
p0u1 14 Posted August 31, 2010 Report Share Posted August 31, 2010 sonds like the head gasket is still gone :-/ did you get it reskimed X2 Link to post Share on other sites
chief ka kar 0 Posted September 1, 2010 Report Share Posted September 1, 2010 Am going with head still warpped hence build up of pressure in the water. Link to post Share on other sites
p0u1 14 Posted September 1, 2010 Report Share Posted September 1, 2010 if your rad pipes expand when the engine is turning over its because theres a head gasket leak and pressure builds in the pipes Link to post Share on other sites
paulo810 0 Posted September 1, 2010 Author Report Share Posted September 1, 2010 Hi there yes head was skimmed and pressure checked for cracks only 6 thou needed to make head square and it does not blow water for about ten minutes and then suddenly boils do they have plastic impeler water pump which could brake i know these are a pig to bleed out but main fault is why it wont start till fuel feed pipe is disconnected can anyone help ? Link to post Share on other sites
