ashmk3 0 Posted September 2, 2010 Report Share Posted September 2, 2010 i did a quick search on here but only found a thread for an obd1 car. i was thinking i had taken all my leads off to do the head gasket, i wonder if the answer to all my problems is the fact i have the leads in the wrong place. they are all in the right place as far as 1-1 2-2 3-3 etc but there are different legnths can anybody tell me which one goes where please eg shortest - 6 cheers Link to post Share on other sites
Antihero1981 8 Posted September 2, 2010 Report Share Posted September 2, 2010 they not marked up on the leads and distributer? i know my coil pack is marked up Link to post Share on other sites
ashmk3 0 Posted September 3, 2010 Author Report Share Posted September 3, 2010 No I know the coil pack is marked up, and the leads go from Cylinder 1 to number 1 on the coil pack etc. But what I wanna know is have I got the lengths in the right order. As in is the shortest lead to no 6 is the longest to number 1 etc. It's obd2 so there is no dizzy cap. Link to post Share on other sites
Lukey. 381 Posted September 3, 2010 Report Share Posted September 3, 2010 it goes 1-3-5[][][]coilpack2-4-6if you ordered them wrong youd know about it! Link to post Share on other sites
ashmk3 0 Posted September 3, 2010 Author Report Share Posted September 3, 2010 No I know the order of the cylinders. There correct as in 1-1 2-2 3-3 etc I want to know if I have put the wrong length lead on the wrong plug. Link to post Share on other sites
Lukey. 381 Posted September 3, 2010 Report Share Posted September 3, 2010 dont quite get you, if they are all connected from the correct cylinder to the correct number on the coilpack then they will be right, as the leads are specific length to reach the specific plug Link to post Share on other sites
ashmk3 0 Posted September 3, 2010 Author Report Share Posted September 3, 2010 Yh that's the thing I was given some cheapo leads there's three that are the same size then two short ones that are different thats all. I have managed to have a play and it's running slightly better. Link to post Share on other sites
Lukey. 381 Posted September 3, 2010 Report Share Posted September 3, 2010 the length of the lead doesnt really matter, its the quality of the lead and the transmission of the spark thats important, you might have duff leads. Gen VW leads are better than any aftermarket even expensive ones Link to post Share on other sites
gavinvr6 0 Posted September 3, 2010 Report Share Posted September 3, 2010 so long as the leads are fitted correctly there should be no matter if they are different lengths, just make sure they clip onto the plug correctly, are you using the correct lead removal tool to re-fit the leads? you flip it upside down to push the leads on.also are the leads used one's? as they could be arcing against the inlet manifold.the lead should have 5 kOhms stamped on the plug end i beleive, atleast thats what my obd1 coil pack engine has, if the leads offer up the incorrect resistance then they wont work correctly. Link to post Share on other sites
