Anyone know the VAG COM measuring blocks for fuel trims?
Since replacing my maf ive been watching the air mass readings and they are coming into line, which is nice, getting a peak reading right where it should be.
For this i jumped into the measuring blocks and found one that gives me real time g/s readings, but now im trying to find the fuel trim readings, according to rosstechs help docs it should be group 032 but this comes up as N/A on my car.
It said in the help doc that the trims should be percentage readings, i found one that has percentage readings, cant remember which group, maybe somewhere around 15 or 16, but they were all labelled as Lambda, the first block had a fluctuating reading of around -2% to -3%, the second had a solid 0% and the third had another fluctuating reading of around -2% to -3%.
If these are the trims then ive been told that anywhere between -10% to +10% is fine right?
Plus are these the fuel trim values? If not which group should i be looking at?
Cheers
