Americans crack me up!
so started reading this thinking 'this should be interesting'
http://forums.vwvortex.com/showthread.php?5021443-Tim-mullen-s-MK3-runs-10.81-131mph-stock-motor-VR6
so in the US their idea of a 'stock motor' has a whopping turbo stuck to it and this 'goes without saying'
"OBD2 MK3, 10 point cage, full exhaust, MT 24.5"x8" slicks on 15" wheels, stock piston/rod motor with just arp rod bolts, stock head, TT 288 Cams, Borg Warner 66mm turbo, modified Kinetic turbo manifold, Juan short runner intake manifold, 630cc injectors, made 465whp at ~17 psi and 511whp at 20.5 psi and ran 22-23 psi tops at the track. The engine, boost, and wideband is controlled with a Lugtronic standalone and wire harness. " sounds pretty stock to me 8-)
