New NGK plugs for a standard engine?
ive looked in the parts recommenders and they say BKR5EKUP for a 97. BKR5EKU for before 95?
but some are saying BKR6E or BKR7E or BKR5EIX.
which ones are going to be right? also is the gap supposed to be 0.8mm or 0.7mm as things say both?
or is 0.7mm for pre 95 and 0.8 for after?
cheers
the p at the end of 1st one you put is platinum tip. there are what i have and find much better than non platinum ones.
if you do get the platinum ones the gap is already set as they have 2 electrodes and you can damage the core by trying to change gaps.
only down side is they're around 5quid each.
thanks for the info about the cheaper plugs nat, i decided to go with those ones just with a stock 5 heat rating BKR5E.
seems to be too much about the platinums (and dual electrode in general) being hit and miss on a google search and read for me, ill stick with cheap ass copper and replace them in half the interval.
Now to wait for these, new OEM leads and OEM coilpack to arrive, my car shat its coilpack just cruising down a main road, luckily i could coast into a layby
