hobbsy 0 Posted January 22, 2005 Report Share Posted January 22, 2005 If I put the drivers window all the way down in my vr and then try to close it it gets half way upo and then goes all the way down again. It was messing about today and took 10 mins to get it to shut, needless to say I wont be opening it again! Thought it could be the switch or the regulator, anyone had similar probs? Link to post Share on other sites
Devilfish 0 Posted January 22, 2005 Report Share Posted January 22, 2005 Dude i have the EXACT same problem, what you have to do is nudge it up slowly tapping the up button..i would love a fix for this! Link to post Share on other sites
dub_weiser 0 Posted January 22, 2005 Report Share Posted January 22, 2005 Windows tend to be a common fault on VW's in general. Always screwing up in some form. I've had it happen twice when the glass just drops, luckily not on the VR. Just a bit of a pain regardless Link to post Share on other sites
jonvr6highline 0 Posted January 23, 2005 Report Share Posted January 23, 2005 My passenger one does that sometimes. I press the button so that it shuts automatically, it shuts and the drops halfway down again. Couple of times later, it is OK! !amazed Link to post Share on other sites
hobbsy 0 Posted January 23, 2005 Author Report Share Posted January 23, 2005 It is a right pain, will prob try replacing regulator when the weather heats up a bit, but for now i m just noy gonna use it! Link to post Share on other sites
HazelVR6 0 Posted January 26, 2005 Report Share Posted January 26, 2005 Hi, I am new on here but think I might have the answer. I Had the same problem with my 96 golf and after some careful thought worked out that the motor thinks there is an obstruction and keeps winding back down. So, I got some silicone spray (amour all etc) and sprayed it down the runners either side of window when the window was down and viola it stopped for about three months. I think the permenent solution is to take the door apart and re-grease window mech, but I don't know how the door panel comes off !! Link to post Share on other sites
nedlands 0 Posted January 27, 2005 Report Share Posted January 27, 2005 Check the connector between the door and a-pillar. If the connection is loose/damaged/corroded this can do all kind of weird things with your windows. Also worth ceking the condition of the cable from the connector to the motor (brown thicker cable) which can become brittle and break causing similar issues Link to post Share on other sites
