Gazbarber1982 3 Posted October 8, 2010 Report Share Posted October 8, 2010 Hello all. After spending lots of money on all kinds of bits to try and get my car running right, I'm still having no luck. If I clear the fault codes with VAGCOM, the car runs OK for a while until the lambda learned part load in group 4 on VAGCOM get's to -25% When I'm driving the car around the lambda regulation tends to stay at about -25% unless I've got my foot down and then it hovers around 0%. I've checked around most of the hoses in the engine bay looking for vacuum leaks but can't get this fault fixed. The only fault codes I get are:-Monday, 04 October 2010, 17:33:54VAG-COM Version: Release 409.1-SControl Module Part Number: 021 906 256 Component and/or Version: MOTRONIC M3.8.1 HS V02 Software Coding: 00000 Work Shop Code: WSC 013171 Fault Found:00561 - Mixture Adaptation 15-00 - Adaptation Limit (Add) Not Reached---------------------------------------------------------------------------Friday, 08 October 2010, 18:56:04VAG-COM Version: Release 409.1-SControl Module Part Number: 021 906 256 Component and/or Version: MOTRONIC M3.8.1 HS V02 Software Coding: 00000 Work Shop Code: WSC 013171 Fault Found:00561 - Mixture Adaptation 13-00 - Adaptation Limit (Mul) Not Reached---------------------------------------------------------------------------I've fitted new lambda, MAF, air filter, plugs, leads, coolant temp sensors (all genuine apart from filter)My car is OBD2 and supercharged. Vince remapped it in June and I've had this problem since August.Sorry it's so long winded but I'm getting desperate now. It's really annoying!!!Thanks in advance,Gaz. Link to post Share on other sites
Gazbarber1982 3 Posted October 15, 2010 Author Report Share Posted October 15, 2010 Bump Link to post Share on other sites
UnitedMotorsport 55 Posted October 15, 2010 Report Share Posted October 15, 2010 What size injectors are you running? Link to post Share on other sites
Gazbarber1982 3 Posted October 15, 2010 Author Report Share Posted October 15, 2010 Standard brown injectors. There on the way back from ultrasonic cleaning at the min and I should have them fitted tomorrow sometime. Ive also fitted a brand new throttle body (genuine) just in case any of the idle sensors or TPS wasplaying up. Before fitting the new TB, I already tried adapting the old one in group 98 on vagcom. It said adaption OK but the butterfly seemed to judder rather than sweep? Link to post Share on other sites
UnitedMotorsport 55 Posted October 16, 2010 Report Share Posted October 16, 2010 Run the car up to temperature and With VAG COM clear the fault codes, even if none appear.Look at block 99, box 4. This tells you if closed loop lambda control is active or not. When it becomes active, then look at box 3 of block 99, this is live lambda trim.Take a note of these values.Put the standard chip back into the ECU and let it idle up to temperatureWith VAG COM clear the fault codes, even if none appear.Again Look at block 99, box 4. This tells you if closed loop lambda control is active or not. When it becomes active, then look at box 3 of block 99, this is live lambda trim.Take a note of these values.Let us know what you find. Link to post Share on other sites
Gazbarber1982 3 Posted October 16, 2010 Author Report Share Posted October 16, 2010 I've not got the standard chip. When Vince remapped the car, he never give me a standard chip. I'm going back down to him on Wednesday to see if I can get this problem sorted. If my injectors come back today, I'll get it back together and get you the readings. Ive checked them before, just can't remember the values! Link to post Share on other sites
Gazbarber1982 3 Posted October 16, 2010 Author Report Share Posted October 16, 2010 Standard brown injectors. There on the way back from ultrasonic cleaning at the min and I should have them fitted tomorrow sometime. Ive also fitted a brand new throttle body (genuine) just in case any of the idle sensors or TPS wasplaying up. Before fitting the new TB, I already tried adapting the old one in group 98 on vagcom. It said adaption OK but the butterfly seemed to judder rather than sweep? Link to post Share on other sites
Gazbarber1982 3 Posted October 21, 2010 Author Report Share Posted October 21, 2010 Problem sorted now. Turned out the air flow meter was too close to the charger! Link to post Share on other sites
