garrett281083 0 Posted October 14, 2010 Report Share Posted October 14, 2010 im getting idleproblems, tried blocking off the missing pipe but engine cuts out. and its taking way tomuch air in left off. its a little t piece that comes just after a white valve of some sort. Link to post Share on other sites
garrett281083 0 Posted October 14, 2010 Author Report Share Posted October 14, 2010 correction its a black piece with 2 outlets coming off it. please help me, where do they go. Link to post Share on other sites
p0u1 14 Posted October 14, 2010 Report Share Posted October 14, 2010 are you on about the pipe going from the intake manifold to brake servo, because that has two outlets and my two are just blocked off Link to post Share on other sites
garrett281083 0 Posted October 14, 2010 Author Report Share Posted October 14, 2010 yes mate thats the 1s. thats weird as i have 1 going through my bulk head, and 1 that i cant find a pipe for. if i block it off it stalls when i change gear. i cant figure it out at all. Link to post Share on other sites
p0u1 14 Posted October 15, 2010 Report Share Posted October 15, 2010 have you got a turbo? Link to post Share on other sites
garrett281083 0 Posted October 15, 2010 Author Report Share Posted October 15, 2010 no turbo mate, im told today i have a gti ecu with a vr6 engine. also told this should run fine. but i had the car decatted and they said i need a different lamb sensor. is this correct. car is goingto stealth on thurs to be set up correctly. Link to post Share on other sites
p0u1 14 Posted October 16, 2010 Report Share Posted October 16, 2010 you cant use the gti ecu, well im very sure you cant its made for a 4 pot not 6 apon many other things with that ecu shouldnt work. Link to post Share on other sites
garrett281083 0 Posted October 16, 2010 Author Report Share Posted October 16, 2010 im told today hes speaking out of his anus by another 3 vw specialists. also told the lamb sensor doesnt need to be changed for a decat. managed to sort out my performance issues today by simply refitting the new ht leads properly. still suffering when changng gear and clutch is in. keeps going to cut out and resueing itself. could my lamb sensor be damaged Link to post Share on other sites
