Caddyslammed 16 Posted October 15, 2010 Report Share Posted October 15, 2010 In my VR, the knob, (right hand one) that controls the flap for directing the airflow from the heater to feet-face-windscreen etc, just rotates freely, it stops at each extreme but does not move the flap, the air just comes out of the vents into my face, is this an easy fix do you know?, i wouldnt mind so much if it was stuck on the windscreen for demisting but it isnt..Help please Link to post Share on other sites
Dave_ciw 507 Posted October 15, 2010 Report Share Posted October 15, 2010 Hi fella will send you a complete new 3 knob set for £15 delivered to your door mate.Regards Link to post Share on other sites
Caddyslammed 16 Posted October 16, 2010 Author Report Share Posted October 16, 2010 Hi fella will send you a complete new 3 knob set for £15 delivered to your door mate.RegardsIs that what i need though? i am asking if its fixable? Link to post Share on other sites
Lukey. 381 Posted October 16, 2010 Report Share Posted October 16, 2010 you need take the heater control panel out to have a look and see if the cables are all fastened in or its all snapped up at the back Link to post Share on other sites
CALICO 130 Posted October 16, 2010 Report Share Posted October 16, 2010 i think the adjuster for the other end of the cable is on the side of the heater box by your left ankle you could adjust it manually for now Link to post Share on other sites
Ben Seabrook 4 Posted October 16, 2010 Report Share Posted October 16, 2010 In my VR' date=' the knob, (right hand one) that controls the flap for directing the airflow from the heater to feet-face-windscreen etc, just rotates freely, it stops at each extreme but does not move the flap, the air just comes out of the vents into my face, is this an easy fix do you know?, i wouldnt mind so much if it was stuck on the windscreen for demisting but it isnt..Help please [/quote']yes mate I think it just clips on to the back of the fins you can remove it by undoing the screws behind the vents and then a little bit of the surrounding dash but otherwise just manually move the vents away with your fingers Link to post Share on other sites
Caddyslammed 16 Posted February 13, 2011 Author Report Share Posted February 13, 2011 Right i have done nothing about this problem yet, so i would like to fix it, D@VeR6, you still got a heater control panel please?, if thats what i need?, i still havent taken my old one out, but i assume something has broken off and released the cable? Link to post Share on other sites
Caddyslammed 16 Posted February 13, 2011 Author Report Share Posted February 13, 2011 i suppose one of these may have what i need? Link to post Share on other sites
Caddyslammed 16 Posted February 14, 2011 Author Report Share Posted February 14, 2011 Any advice please guys? Link to post Share on other sites
Dave_ciw 507 Posted February 14, 2011 Report Share Posted February 14, 2011 I can send you one mate no worries Link to post Share on other sites
Caddyslammed 16 Posted February 14, 2011 Author Report Share Posted February 14, 2011 Do you think something has broken off mine?, i can't check as my car is in a bodyshop Link to post Share on other sites
VR6Pete 1,455 Posted February 14, 2011 Report Share Posted February 14, 2011 could be a broken tab / sheered cog.. it happened on my corrado, but the reason the tab / cog broke was because the de-mister cable was mashed, which meant it was putting stress on the heater controls...£9 from the dealer for the corrado for the cable. worth taking out your control pannel and see if the bowden cables move freely! Link to post Share on other sites
Caddyslammed 16 Posted February 14, 2011 Author Report Share Posted February 14, 2011 Is that the dash out to swap cable? Link to post Share on other sites
eastwood john 1 Posted February 15, 2011 Report Share Posted February 15, 2011 no mate, will need to get behind the kick panels though, Link to post Share on other sites
Caddyslammed 16 Posted February 15, 2011 Author Report Share Posted February 15, 2011 Oh ok thanks mate , D@VeR6, how much for the control panel without A/C delivered then please? Link to post Share on other sites
makster28 0 Posted March 7, 2011 Report Share Posted March 7, 2011 installed new coolant today and took advice from here to leave the cap off with heaters on full bore in the expansion tackle bubles were riising all the time all of my hoses get hot even the matrix ones my temp reads 90 and fans kick in regular but i still have no heat coming in the car also jsut put a new thermostat and new housing in,can anyone shed any light on this,many thanks Link to post Share on other sites
