  • 3 weeks later...
mine needed doing as well so decided to have a go myself,got some power flex ones ,hardest bit about the job for me was getting the old bushes outer metal casing off ended up just sawing with a hacksaw blade remebering to keep it level,did find a guide on how to do it will try and find it and post up here ,if you need decide to have a go yourself give us shout will try and pop down n help you out if you want
Support the rear of the car on axle stands on the innder chassis box section in front of the axle mounts.
Disconnect the ABS sensors and feed them out the bungs in the floor
Disconnect the spring clips (2 on each side) on each end of the rear beam flexi hoses and free the flexis from the rear beam.
Disconnect each brake line from the plastic clips along the trailing arms
Unclip the calliper flexi hose spring mount using a flat blade screwdriver and a gentle tap on the retaining tab (inside the box section where the lower shock bolts onto the trailing arm) with a hammer
Disconnect handbrake cable from its mountings along the trailing arms.
Free the axle beam bolts and drop down using a trolley jack given nothing but the callipers are now connected. Alternatively unbolt callipers and tiewrap to rear shocks, unbolt the lower shock mounts and remove axle from car and work on the beam at leisure.
Get drill out (I used an 8mm bit) and chase around the inside of each old axle bush until the centre falls out.
Here's the sneaky part - You can use a hacksaw or compressor and air saw.... but I'd get comfy if doing it manually!
Sit there getting bored/swearing/whatever and cut through the length of the old bush to release the interference fit/pressure, spray in some plusgas/wd40 etc and then chap out with a chisel hammer.
Shove in new polybushes (large side to inside) using plenty of copper grease, tap in stainless centres past flush from the inside - leave sitting proud (See next bit) on the outside by about 2mm so the inner polybush can be compressed and forced past the inside of the mountinng brackets . Offer up axle and then wonder how the **** to get it back in as it's now about 1/2" too wide with the new polybushes.
Beg steal or borrow a 2nd trolleyjack and use both trolley jacks to raise the front of the axle into position. You might find that the axle tries to 'slide back' and out of the brackets so you need to find a way of keeping it in position as it's forced into the brackets. We used a chisel sticking out the ARB mounting and used a giant adjustable compressable stilson type thingy hooked around the chisel and the front part of the mounting bracket which we wound in as we jacked the pivot point into position; this worked quite well..
  • 1 year later...
