carl7777 0 Posted October 24, 2010 Report Share Posted October 24, 2010 hi ive just lowered my vr6..but having done so the nearside wheel is cambered,i wondering if theres a correct way of fitting them,i have a look at other posts but cant find anything,...are the top and bottom mounts both fully tightened whilst car is jacked etc ? cheers carl Link to post Share on other sites
Lukey. 381 Posted October 24, 2010 Report Share Posted October 24, 2010 theres camber adjustement on the 2 bottom bolts, you adjust it then tighten them up Link to post Share on other sites
carl7777 0 Posted October 25, 2010 Author Report Share Posted October 25, 2010 do i adjust by moving the hub to desired position then tighten bolts at bottom of strut then tighten the top bolt ? Link to post Share on other sites
FrostyCab 0 Posted October 27, 2010 Report Share Posted October 27, 2010 Yep, thats it. Link to post Share on other sites
carl7777 0 Posted October 27, 2010 Author Report Share Posted October 27, 2010 im half way through it and done one side and looks so much better,should there be a gap beween the rubber at the top of the shock and the shock tower,everything is tight and theres no movemet Link to post Share on other sites
