VeedubVR 0 Posted October 29, 2010 Report Share Posted October 29, 2010 I bought brand new falkens on the first of september and the front tyres might need replacing already. The back look like I just bought them today. I am running camber up front so the inside is where its worn. The rest has about 4mm. Will they need changing if its just the inside that's worn down? I also noticed thatt on the front tyres the tread isn't flat to the tyre. Its stood up at the end (kinda had explain) but it doesn't look normal.Thanks Link to post Share on other sites
Apollo 0 Posted October 29, 2010 Report Share Posted October 29, 2010 Stood up looks like a wedge from one side? If so thats due to the camber it wears the tyre unevenly and you will need to change your tyre if ....The legal limit for minimum depth of the tread on your tyres is 1.6 millimetres, across the central ¾ of the tread around the complete circumference of the tyre. Link to post Share on other sites
VeedubVR 0 Posted October 29, 2010 Author Report Share Posted October 29, 2010 Yeah. If you at the tyre the tread is like angled up.Just checked the mileage and they have only done 1500miles I've got pics of one of the tyre, just need to upload them to the comuter. What you mean central 3/4s. Got a pic or a diagram? Thanks Link to post Share on other sites
spadam 7 Posted October 29, 2010 Report Share Posted October 29, 2010 When running negative camber you will eat threw tyres. I went through 3 pairs of tyres on the front wheels within 9 months now i have removed my camber back to factory settings so i dont pay more on tyres then i do on fuel. Link to post Share on other sites
Lukey. 381 Posted October 29, 2010 Report Share Posted October 29, 2010 tyre wear patterns and causesmeasured wear across the central 3/4 like so Link to post Share on other sites
VeedubVR 0 Posted October 29, 2010 Author Report Share Posted October 29, 2010 ahhh I seewell falkens have 3 parts the big centre section and inner and outer tread. So the innder and outer tread can be down aslong as the centre section is over 1.6mm? Link to post Share on other sites
Lukey. 381 Posted October 29, 2010 Report Share Posted October 29, 2010 yes, unless youre like down to the canvas on the shoulder lol Link to post Share on other sites
VRRob 0 Posted October 29, 2010 Report Share Posted October 29, 2010 If its not too bad on the edge turn the tyres on the rim and swap them side to side that will get a bit more wear out of them. Or just swap front to back (if they are the same size) but obviously you still need to sort the camber out. Link to post Share on other sites
Special K 81 0 Posted October 29, 2010 Report Share Posted October 29, 2010 hey fella beat this, brand new toyo proxes T1R 'sfitted only about 20 days ago.....destroyed to almost no tread. Bad alignment, running negative camber and way too much possitive toe(pointing in) but no places will touch it and the ones that will want stupid money. Hopefully sorted tomorrow. Not the camber that has killed mine its the toe as wheels effectively being pushed along rather than rolling Anyway negative camber will wear inner tread, but shouldnt wear too much if its just 1 degree negative. Just make sure its tracked and no positive toe Link to post Share on other sites
oldmandon 1 Posted October 29, 2010 Report Share Posted October 29, 2010 hey fella beat this' date=' brand new toyo proxes T1R 'sfitted only about 20 days ago.....destroyed to almost no tread. Bad alignment, running negative camber and way too much possitive toe(pointing in) but no places will touch it and the ones that will want stupid money. Hopefully sorted tomorrow. Not the camber that has killed mine its the toe as wheels effectively being pushed along rather than rolling Anyway negative camber will wear inner tread, but shouldnt wear too much if its just 1 degree negative. Just make sure its tracked and no positive toe [/quote']Are you STILL have trouble? thought you were getting things cut etc........ Link to post Share on other sites
